Introduction: IHip Captain America Headphone-jack Repair
Picture of IHip Captain America Headphone-jack Repair
My son bought these about a month and half ago and they stopped working. I narrowed it down to the mini jack.
Things you will need:
Helping Hands for soldering
Soldering Iron
Solder (.022")
Razor (or sharp knife)
Heat shrink tubing
Straight or angled pick
Small Phillips head screw driver
The Original Super Glue (Cyanoacrylate)
Step 1: Cushion Removal
Picture of Cushion Removal
I started by pulling back the blue padded cushion back. Simply pinch the cushion and pull the cushion back. This gave me access to the 3 phillips head screws.
Step 2: Wire Color Verification
Picture of Wire Color Verification
After removing the 3 screws, I was able to see which colored wire went to the right-side headphone.
Step 3: Wire Preparation
Picture of Wire Preparation
Next, I cut the mini jack wire 1/2" above the end of the mini jack. I stripped the insulation back and pulled the 3 wires out (Ground, Green, Red). Cut the wires in a staggered pattern, ground wire longest, red wire shorter, and the green wire shortest. Use a razor to strip the insulation off the wires. It may not seem like it, but the green, red, and even copper color is insulation, its Acrylic. Use the razor to carefully peel off the acrylic insulation off the three tips of the wires, including the ground wire. The mini jack casing needed to be hollowed out, I used a 45 degree pick to remove any insulation inside the casing. (Note: keep the metal casing on the wire down stream from your bare wires. If your solder joint is too big, you may not be able to slip it on later).
Step 4: 3.5mm Jack Soldering
Picture of 3.5mm Jack Soldering
Now that you have bare wired tips, solder them to the 3.5mm jack.
Step 5: Heatshrink the Soldering Point
Picture of Heatshrink the Soldering Point
After soldering, I insulated the wires with three overlapping strips of heat shrink tubbing. One is more than enough, but I wanted to have a tight fit when the joint was inserted into the metal tube (next step).
Step 6: Casing Installation & Finished
Picture of Casing Installation & Finished
Next, we will pull the metal casing over the solder joint. But first, I copiously applied the Original Super Glue (Cyanoacrylate) over the heat shrink in order to keep the casing from slipping off easily. After you apply the glue over the heatshrink, slide the casing over heat shrink and hold in place for a few minutes while drying. My son, now has a set of working head phones, love you bud.
Harvard82 (author)2012-03-06
My daughter just had this same issue....the headphones are sitting in my workshop waiting for your instructable to show me the way. Thanks!
tin-art (author)2012-07-09
Those would be cool if you placed two Capt. Amer. shields to the back from those C.Amer. action figure toys. Would give them a rounded sharp too.
About This Instructable
7,473views
2favorites
License:
Bio: I Love to build anything. I Love building up people and building projects with them. There is nothing that is impossible. I enjoy all sports ... More »
More by jlgomez90:iHip Captain America Headphone-jack repair
Add instructable to:
