iPad Dual-USB Charging cable
 by juniortan
Charge your iPad using 2 USB ports, twice as fast as on a single USB port.
1. Cut 2 iPod|iPhone|iPad Cables
2. Identify and verify the cables that carry power (in case you are not using the apple supplied cables) - usually they are red (+5V) and black (G)
3. On one of the USB cables, cut and isolate the data cables (the two cables NOT power related as in item 2 above)
4. Reconnect everything (I used a small veroboard, but just simple splicing/soldering should be okay) - Just make sure you connect the power cables IN PARALLEL.
5. Insulate and test (I used Sugru to create a more hardy enclosure)
This has been tested to bring up a 7% battery charge iPad to full in  about 5 hours - more testing is underway for validation)
scottie.j.murray says: Nov 23, 2012. 5:02 AM
Hi mate :)
I followed your directions to the 't', wires were definitely in parallel, spliced and soldered, tested with a multimeter to make sure it wasn't shorting and it still doesn't work :(
I have 'the new iPad' aka iPad 3. When I plug in one of the usb cables when the 30 pin is connected, it charges, but as soon as I plug the 2nd usb in, it doesn't want to play any more :( Any ideas? I would be eternally grateful!
grundisimo says: Jul 23, 2011. 12:06 PM
One USB cable could bring the charge up faster. And, if you aren't careful, using this could ruin the iPad you just spent 500 plus dollars on.
jgosselin in reply to grundisimoNov 27, 2011. 8:46 PM
if you are unfamiliar with series and parallel wiring you should look it up, it is very helpful when dealing with electrical instructables. because the iPad is rated for 5v/10watts by apple. that's 2 amps if this is connected to a PC it would never ever be in danger besides faulty wiring as a pc only outputs max 5.25volts/900 mA's over a standard USB port. not to mention if u supply access amperage it just won't use it. so to readdress the point.. as long as you clearly can ID the 5+volt and gnd and connect them correctly in PARALLEL this charger is just about equal to the wall wart they ship it with.
NOTICE: some PC's have dedicated charging ports they can output around 1.5-1.8amps so you technically wouldn't even need this cable if your PC had such ports, but they only come on high end motherboards.
lebowski says: Feb 8, 2011. 10:40 AM
Clever
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
