The following project will show you how to take 3D Solidwork's renderings and 2D Illustrator files and create a minimalist iPhone boombox. The boombox is my design and creation. Originally for a production class, I designed and created the boombox in an attempt to design, render and create using computer programs. Other goals of the object were to hide witness marks and create a minimalist and retro design. Please feel free to contact me with questions or with photos of the boombox you create using my Instructable, especially if you use different materials or components.
If you like the design and the way I took the idea from computer to reality please vote for me in the Make It Real competition!
This Instructable is for the the Make It Real competition. Thanks to the judges for giving me the opportunity to continue design. Winning a 3D printer while still in school would allow me to do incredible thing like rapid prototyping, form studies and so much more.
Thank you for viewing and voting!
Step 1: Step 1: Materials
Materials:
1/2 inch MDF (Board Atleast 14 x 12)
1/4 inch MDF (Board Atleast 14 x 12)
1/4 inch Clear Acrylic
5/8 inch Dowel
1/2 inch Cloth Elastic Band
Mini Rocker Switch
5mm LED
AAA Battery Pack
Altec Lansing IMT227 OrbitM Speaker
Electrical Wire
1/4w 62 OHM Resister
Where to Purchase the Speaker:
http://www.amazon.com/Altec-Lansing-Technologies-IMT227-Portable/dp/B006KZ0R1Q/ref=sr_1_1?ie=UTF8&qid=1329438061&sr=8-1
Step 2: Step 2: Tools
Tools:
Laser Cutter
CNC Router
Soldering Iron
Hand Router
5/8 inch Drill Bit
Wire Cutters
Step 3: Step 3: Cut MDF
Download the 3D Solidwork's files that I have uploaded. Send the files to a CNC Router. Cut out front and back panels. Cutting out extra's will allow room for error or the opportunity  to make multiples.
This is your chance to experiment with other materials, I'd love to see some of these in fine woods!
Step 4: Step 4: Cut Acrylic and MDF
Download the Adobe Illustrator files I have uploaded. Using a laser cutter, cut out the acrylic middle insert and the two 1/4 inch MDF inserts.
Step 6: Step 6: Finalize MDF Insert
Finalize the MDF insert by wrapping your cloth elastic band over the cutout and using a small amount of epoxy on the sides.
Step 7: Step 7: Wire Speaker and Lights
Begin to take apart your Altec Lansing speaker. Be very careful during this step, this is the life of your object and you don't want to end up buying more than you need like I did. You will be discarding most of the casing but be careful as you remove the faceplate. Additional screws can be accessed through the bottom of the speaker. You will most likely need a hex key and a small screwdriver. DO NOT LET THE AUXILIARY WIRE GET CUT. Be carefull when getting the speaker out!
Included in the images is the part of the case you will need as well as what the speaker looks like. You will be wiring in parallel so that all components receive equal amounts of power. Below is  website for learning how to wire in parallel.
http://www.termpro.com/asp/pubs.asp?ID=124
Be sure to wire slowly and have a good understanding of how to do it before you start to solder everything. TEST, it's important. I didn't know anything about how to wire the parts together so i started by setting up one LED light, then adding a switch, then more LED lights and eventually the speaker.
Step 8: Step 8: Sand, Glue and Stain (Optional)
Depending on the CNC router you used and how careful you were during construction you may need to do some finishing work on your speaker. I painted the speaker cap white for a nice plain detail. You can further protect your MDF panels by taking them off and coating them with a clear staining agent. If you used a wood besides MDF then play around with other stains and protective agents.
You are also going to want to glue the speaker to it's cap from the inside and glue the speaker plate to the bottom panel of MDF. This will secure your speaker and reduce rattling.
While the pegs hold the panels together nicely you may want to use a little glue and clamp the panels together over night. You wont have access to the inside anymore so make sure everything is strongly secured, wired and soldered inside if you do this!
Step 9: Step 9: Enjoy!
If you just made it, show that thing off!
rebek.2210 says: Dec 25, 2012. 5:23 PM
wow guy! this project is awesome! i just love it! continue doing things like this one! just one word: AMAZING!
man from mars says: Oct 25, 2012. 7:03 AM
Awesome project, I would just like to know how it looks from the back and also how is it all held together
Thank you
Yaanu says: Oct 5, 2012. 4:57 PM
Would it be possible to alter/adjust the instructions in order to accommodate for the new dimensions of the iPhone 5 or the new iPod touch, as well as potential stereo output?
Schooniedude says: Aug 5, 2012. 10:53 AM
I must say, that is ballin'.
curious youth says: Feb 17, 2012. 1:55 AM
how do do it without a laser cutter please ? looks great !
marcintosh in reply to curious youthFeb 19, 2012. 8:31 AM
Use a router with a guide or router table.
http://www.amazon.com/b?ie=UTF8&node=552578
The tables are available at all price points.  More expensive = better accuracy.  If you're not going to use a table, I'd suggest a plunge router or work from the outer edge in.
You can route the MDF and the Acrylic as well. Depending on your aesthetic preferences you might like to use MDO instead of MDF http://en.wikipedia.org/wiki/Medium_density_overlay_panel
I
f you choose to, you could replace the MDF with acrylic.  Getting a clean acrylic edge is as simple as buffing with a felt or cotton wheel and rouge both of which are available in any decent hardware store.
http://www.amazon.com/s/ref=nb_sb_noss?url=search-alias%3Daps&field-keywords=buffing+wheels&x=14&y=11
or
http://tinyurl.com/87xnanl
There's really no trick to it just have some pieces to practice on first, some patience and a willingness to endure a few failures at the outset.  If it works the first time you haven't learned anything so there's that solace.
curious youth in reply to marcintoshFeb 23, 2012. 2:16 AM
Great ! thanks for all the info :)
MTriest (author) in reply to curious youthFeb 17, 2012. 8:57 PM
You can download the plans, scale them properly and maybe use a ban saw to cut out the inserts. Let me know
curious youth in reply to MTriestFeb 17, 2012. 10:36 PM
ok thanks. when i get around to doing it ill definately upload pictures
Tomfhowe says: Feb 22, 2012. 1:22 PM
dang sick
andeh says: Feb 21, 2012. 11:09 AM
Very nice! Would be really neat if the LED pulsed to the sound output. Really wish I had access to a laser cutter...
jxke says: Feb 21, 2012. 5:59 AM
You should've went the full mile on this idea. The iphone dock isn't very nice to look at. You could've hard mounted the 3.5 headphone jack for starters and made an actual dock that holds the phone snug instead of that elastic band. Also. since you're using batteries on this for the LED. You should've went ahead and added a second speaker and transistors for amplified sound.
Rebuild it with some better ideas.
ddsouza says: Feb 19, 2012. 5:34 PM
Really neat Idea.. Excellent execution. Brilliant. Any reason you did not make it Stereo???
jonathad says: Feb 19, 2012. 2:49 PM
Awesome instructable. It would be great to add a dock connecter and an extra power pack to charge your iPhone. Hmmm, might just have to try that myself! I might even add solar power, and a USB recharge and a sealed plexiglass face to keep the sand out and to create the ultimate beach boom box. Brilliant.
vincent7520 says: Feb 19, 2012. 2:04 PM
excellent ! …
earlyflyer says: Feb 19, 2012. 7:49 AM
I did not see your Instructable in the Make It Real challenge to vote for it. Is it there and I just missed it?
Great project and well documented in this Instructable. I assume you got a good grade in your class!
MTriest (author) in reply to earlyflyerFeb 19, 2012. 10:31 AM
It has not been accepted yet, and i also havn't gotten a grade back yet, hopefully soon, thanks for trying, check back soon!
jimg16 says: Feb 19, 2012. 7:26 AM
Maybe this could be a Kickstarter project? http://www.kickstarter.com/
dmorro says: Feb 17, 2012. 9:18 PM
Sick. I want me one.
golferkid1990 says: Feb 16, 2012. 11:14 PM
Super dope. Apple needs to buy this idea! What do you think, a mil sound about right? lol.
poqeteer in reply to golferkid1990Feb 17, 2012. 2:49 PM
More likely they'll patent it and sell it back to you... lol
MTriest (author) in reply to golferkid1990Feb 16, 2012. 11:17 PM
haha love it thank you
frankiecatpdx says: Feb 17, 2012. 8:26 AM
This is such an incredible project. I wonder if it could go to mass market by 4th Quarter - everyone will want one. When is the Droid version coming LOL - I want one of each.
isacco says: Feb 17, 2012. 7:10 AM
I like this project very much.
The design is excellent and the make-of is very well illustrated.
Of course, the use of computer-aided cutting has greatly contributed to the perfect finishing, but the design is very original and beautiful.
mingz says: Feb 16, 2012. 11:22 PM
The greatest thing to happen to portable speakers since the boombox.
Reesol says: Feb 16, 2012. 10:25 PM
Simple but looks great good job!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
