3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
iPhone Disassembly - A guide inside the iPhone
Step 4Inside the iPhone
Inside the iPhone
  • last photo ←
Picture 1: Once the sim card is out, you can now free any remaining clips and flip the back case over and lay the two pieces side by side. You now get your first real look at the guts of the iPhone.
Picture 2: Pictured is the battery that is soldered to the logic board, so switching out the batteries are going to be a pain just like on the iPod nanos.
Picture 3: The headphone board is pictured above and is located on the back case to the right. It is very similar to the 3rd and 4th gen style iPod headphone board. It is attached by one cable that controls the audio to the headphone board and the power button.
Picture 4: The headphone board cable can simply be removed by gently prying up on the connection to the logic board.
Picture 5: There are several screws holding the front metal frame on which surround the LCD. There are three on each side.
Picture 6: There is a small gasket covering one screw on the right side of the dock connector on the bottom.
Picture 7: And two on the bottom.
Picture 8: And two on the top.
Picture 9: You can now remove the front metal frame.
Picture 10: Pictured above is the heat shield covering the logic board and the camera. There are three screws holding down the board. One is near the camera and the two longer screws are towards the sides.
Picture 11: You can pop off the camera by gently prying up on the connector to the main board.
Picture 12: There is a small piece of tape holding down one of the antenna cables. You can simply peel off the tape.
Picture 13: There are two accesible cables on the underside of the logic board. These can be popped off just like the other cables mentioned previously.
Picture 14: The battery is held on by adhesive to the front case and soldered to the logic board by three wires. It can be gently pryed up from the bottom to loosen the adhesive.
Picture 15: You can then pull back the logic board and you can see the LCD cable. It is one of the standard iPod connectors and can be tricky if you aren't experienced with them. The locking bar needs to be flipped up and then the cable can slide out.
Picture 16: The iPhone is now disassembled.
5 comments
May 9, 2011. 3:37 PMthemetalburrito says:
This guy doesn't know what he's doing. It doesn't take too much to know that opening a little gadget with a large tool isn't a good idea. Use a case opener tool.
Jul 16, 2010. 11:33 AMfretshr3dder says:
okay so some months ago, my dads first gen iphone had water spilled on the screen. no water got in, but within an hour the bottom half of the screen stopped working. then my first gen i touch broke. so we took them apart to switch the itouch screen with the iphone screen. unfortunately that didnt work. now that i put the iphone together, it doesnt work. my question is: do we need to keep the orange and black peices of tape in the iphone? and if so, were could i get some?
Feb 1, 2009. 2:56 AMhellyeah says:
that is simple , realy hard its my problem , my iphone fall donw and now the superiror part of the lcd dont assume touch , but everything worrks fine...images appear good , but the damm touch on superior part dont work... :( and i dont have garantie.
Dec 29, 2009. 7:16 PMj_dog says:
if you go to ebay . com you can get the screen and everything. it's for like 100 dollars tho. other than that idk wat to do.
May 15, 2009. 8:17 PMj_dog says:
these guys should go deeper. i took out the port and need to replace it. (the port) and there are some parts i need to remove from the old port to put on the new one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:powerbookmedic(PowerbookMedic)
PowerbookMedic offers free repair guides, parts, and repair services for Apple laptops, iPods, and desktops. Visit us at PowerbookMedic.com.
