IPhone/iTouch + IPod Stand From IPhone Box
Published
Introduction: IPhone/iTouch + IPod Stand From IPhone Box
As you can see, this is pretty straightforward. All you have to do is remove the guts from the inner box and cut a few slots for the ipod/iphone/whatevs to fit in there snugly.
Much like this one here: https://www.instructables.com/id/iPhone-Nano-Bluetooth-Headset-Docking-Station/ only a bit cleaner looking. You could put a mini usb hub in there if you wanted, but mine just runs both cables out.
Step 1: Where to Make Cuts...
For each device, cut down each corner about 1/4", and mark a second cut the width of your device toward the middle. These flaps can either be cut or folded and secured. (I taped mine).
For the charge cables: Set your device in its newly cut cradle (on top), and see where the charge cable lines up. Make cuts on either side, and make the cuts at least half the depth of the cardboard. This is so that the device stands more upright and so the charge cable has space to hang freely.
See picture for more obvious explanation. :D The second picture shows the corner cuts better.
Step 2: Cut Hole in Back...
Cut a small hole in the back. It only has to be big enough to fit the end of one USB cable and the other cord while inserting. I just used an exacto knife.
Step 3: Completing.
Slide the charge cables into the box, and have them sticking out a bit. Stuff the leftovers into the back.
So now you can put the inner box in the outer box, and angle it to your heart's content.
I secured it with black electrical tape as to not mess with the decor :P
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    7 Discussions
    admin
    9 years ago
    Hello, and welcome to the Instructables community! It's great that you've decided to tell the world about something you've made by publishing an Instructable. We just wanted to let you know that your project still needs a little more work if you want it to be well received on Instructables. Projects that don't include certain basic elements tend not to get the attention that they deserve, and so we'd love for you to check out the list below of what makes a successful Instructable. Successful projects on Instructables include: - clearly written details of a finished project with instruction - as many steps as are necessary to explain your project - clear images that you took of your project for most, if not all of your steps - an intro image - proper spelling and grammar - appropriate cautions or safety considerations I'll give you another opportunity to make any final changes to your project before we publish it. Once you're all set to go, please republish your project and send me a quick comment letting me know that you've made some changes. I'll give it a quick final check to make sure you're on the right path, and then remove this note. Thanks for your submission and we hope to see your project published soon!
    Should be all set to go now.
    I have an iPod Touch, and I want to do this really bad, but the box isn't like that! Is there some kind of other box I can use?
    I'm sure there is a way you could do it with the iPod box. Any small box with a smaller inside will work.
    So what box are you "snipping" on because i can't really tell what it is.
