3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
iPod PVC Boombox
iPod PVC Boombox
  • last photo ←
I have been (without luck) looking for a beach-proof boombox with an iPod dock.
Aside from a jobsite radio; like a Bosch or Milwaukee, there’s nothing I would kick around the sand. But, these tend to be on the hefty side.So, I decided to build my own. This project went thru several versions. The image attached to this project shows only the two speaker interation. I eventually decided to add a woofer; this iteration is shown in the video link.
Design Goals:
1. Portable
2. Battery Powered and Rechargable
3. Beach/Sand/Waterproof – PVC provides that. And I’m no wizard with building wood boxes.
4. Bawls – Wanted something that could pump out the jams. 25 Watts seems like plenty with the 4″ speakers.
Tools / Materials / Parts & Pieces:
2′ length of 4″ PVC pipe
2 x 4″ PVC 90 degree elbows.
3/4 Plywood board
3 x 4″ drain grates
4″ PVC Tee
Weatherproof Electrical Outlet Cover – Makes a great dock for iPod Nano, Mini and Classic. iPod Touch’s are a little too long for this.
Sure 2x25w Class-D Amplifier - Has enough oomph for this project and is small.
DC 5V 9V 12V Portable Rechargeable CCTV Li-ion battery - Found on eBay. Has 5V USB output for recharging devices AND 12V 2.1mm output for powering the amp.
Audio/Sync Cable for iPhone/iPod (Apple Dock Connector to USB / 3.5mm Audio) – Allows for input into the amplifier and will also charge the iPod off the battery.
2 x Dayton Audio RS100-4 4″ Reference Full-Range Driver 4 Ohm - These sound great paired with the amp above.
1 x Dayton Audio ND105-4 4″ Aluminum Cone Midbass Driver
2 x Passive Crossovers - Found on eBay.
Video of Completed Project !
Ultimately this turned out to be a little too heavy and I opted to put all the guts into a 16" toolbox. This is shown in the attached images.
11 comments
Feb 1, 2012. 8:51 AMTenTwelve says:
Could give more details on that battery and how you charge it. I have iPhone/iPod dock project in mind and I've been hard pressed to find a battery that fits my needs. Thanks!
Feb 1, 2012. 11:28 AMTenTwelve says:
Oh cool.... I was hoping it came out of it's housing relatively easy. Do you know off hand if you can somehow wire it so you can both power an amp and charge simultaneously? I did find the battery on eBay and I noticed the 12v port is for both input and output. Thanks for your insight.
Aug 5, 2011. 7:52 PMogmosic says:
Great Job! I was just starting this build for a on-job site radio that can take some bumping around and also puts out some great LOUD sound.
Concerning your speakers, is your mid-bass airspace separate from your full range or do all three share the same space?
Can we see a video of your final version?
Sep 1, 2011. 11:35 AMogmosic says:
How did you wire all three speakers to the 2 channel amp?
Jul 14, 2011. 8:46 AMElectronics Man says:
Hey this is a good idea!!!
Jul 13, 2011. 6:49 AMvishalapr says:
This is useful!Well done!Very inspiring!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
6
Author:mwheeler3
