3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
iPod Powered Amplified Speaker
When looking at a pinout sheet for Apple's propriatary connector, I noticed something that got me excited- a 3.3 volt output! Originally intended to power accesories such as the early plug-in cameras, I realized this could be hijacked for a different purpose- to power an amplifier. This idea led to the birth of the microJammer.
The microJammer is a small, amplified iPod speaker. since it uses the iPod's battery for power, the speaker's size is very, very small; less than an inch in any direction. It uses a common 2 transistor amplifier circuit, and uses the headphone jack as the signal input. It is by no means a micro sized boom box, but the volume is comparable to an iPod touch's internal speaker, with the sound being a little more bassy and clearer. Seeing as it relies on the ipod's internal battery, the iPod's battery life is cut down drasticly, so this is not intended to be used all day. But for sharing music with others on the go, this cant be beat!
Step 1Parts and Pieces
Parts and Pieces
The ciruit uses only 5 parts (not including the speaker)- all very common and easy to find. the parts are as follows:
NPN Transistor- 2N3904 or BC548
PNP Transistor- 2N3906 or BC327
10 uF capacitor
4.7k ohm resistor
1M ohm resistor
As for the driver, the smaller the better- to a point. You dont want to use a driver from earbuds, or a super cheap driver. Drivers from over-ear headphones are great, as well as speakers form portable DVD players. I got mine from one of those. They are Panasonic brand and actually have very good sound. A good way to tell what kind of driver would be best is by what it was from- if you find a driver used by something that plays audio, it would probably be a safe bet for this application.
Other parts that are needed include:
1/8 inch headphone plug (from old headphones)
iPod connector
Enclosure
A word about the ipod connector- I recommend vandalising a USB cable for the connector, but DO NOT use a new cable. The new one has contacts in the connector only for the USB functions- USB power +/-, and signal +/-. The older connectors have all of the contacts in the connector in place, including the one we need to power the speaker.
And as for the enclosure- Anything small will work. I was originally going to use an altoids tin, but it was too big. (what does that say about the size of this thing?) So next I tried a Tic-Tac container, which as difficult to cut a hole for the speaker, so it was scrapped. I then came across the top part from an old flashlight, which was the exzct diameter of the driver I was using, so i chose that. If you end up using something mad of metal like I did (in my case anodized aluminum) make sure that the amp does not accidentally short circuit against the side of the enclosure.
11 comments
May 13, 2012. 7:50 AMsgvineria says:
hey man that's awesome :) cool. i used that with bigger voltage and it worked to thank's.
Mar 23, 2012. 10:45 AMjtc10512 says:
What if you could get sound from the dock connector instead? I mean, you'd just have to put a very small pot on it, but would that work?
Feb 17, 2012. 10:50 AMlukeD says:
Hey, nice ible *5!!!
can I put a little speaker (4ohm, dont know the watts) to this speaker?
-LukeD
Jan 29, 2012. 4:16 AMivanjacob says:
cool! im sad i bought a android now XP
Jan 25, 2012. 7:49 PMfreeza36 says:
i have that same ipod, but mine is orange
Nov 28, 2011. 7:54 PMastroboy907 says:
Beautiful! Thats pretty much all I have to say. Nice easy hack and a very elegant product. Thanks for posting this!
Nov 26, 2011. 3:49 AMcrtn2 says:
you don't need headphone cable. The apple dock connector also has audio otuput.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
28
Author:JoeBeau
Why fix it if it ain't broken? Cause it's fun!
