iPod/iPhone bicycle mount (on the cheap)
 by TheCreative
Living in Brighton UK, I've got pretty decent velodrome (568 metres) in my local park. Now, riding a track of that distance with its long straights gets really dull without music. Bottom line.. I couldn't be bothered to buy an iPod mount, so I decided to make one using bits I already had.
Excuse the picture quality it was taken with an old 6mp samsung compact.
Step 1: What you'll need
You will need:
An old reflector: (this is kind of essential I don't know how I would have done this without it.) You must have the bracket as that will be the bit you're using. The reflector itself can be used another way (if riding fixed) as showed below
Two picture hanger things: I don't know what you call them and as you can see mine are different sizes but they can be bought from anywhere whether it be ASDA (Walmart) or B&Q.
Nuts and Bolts: Details in the picture (With the exception of '5x20mm' I don't know what any of that means.)
A spacer of sorts: In my case my handlebars were a tad narrow for the clamp which meant I needed to use one. (A bit of blue tack would do it.)
Screwdriver: Obviously the type depends on your bolts.
iPod/iPhone (or similar)
Advisory case:
 To avoid material damage to your device.
Ruler's just for show.
carlo$ says: Mar 29, 2013. 5:43 PM
nice
ejsilver26 says: Jul 30, 2012. 6:38 AM
Nice 'ible. Simple, yet very usefull and I like the amount of photos. It is not just for iPod/iPhones, however, as it will work with most smartphones. I am looking at using this design for my bike for my rides. I am wondering why there is no bracket at the bottom to prevent slipping, is it that good at holding it that it does not need it?
EJ
(voted)
TheCreative (author) in reply to ejsilver26Jul 30, 2012. 12:19 PM
Good question,
Well on my iPod I have a silicon case/skin. This provides ample friction to hold it securely, because of this I didn't think it needed a bottom bracket. However, having said that the bottom of my iPod does rest my stem a little bit. If you don't have a case for your device please find a way to cushion your device against the brackets e.g. with blu tack otherwise there won't be enough friction to assure stability and you may cosmetically damage your device.
Thanks,
Joe
ejsilver26 in reply to TheCreativeJul 30, 2012. 4:59 PM
I think I'll look at adding a bottom bracket or something to ensure itis tiht. I might also see how to protect against water (zip lock) . I have the Samsung Galaxy S II with an Otterbox, so it should be like yours. I should make one for my Samsung Tablet too.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
