Step 5Robot Right
The mast was actually part of an off the shelf adjustable tripod stand. One leg was removed from the tripod and then mounted upside down with a camera fixed to the top. Typically, routing of the USB camera wiring becomes an issue when the mast is adjusted for different lengths. However, in this case a commonly available retracted USB cord was used in conjunction with the telescoping mast to automically adjust the cable length with the telecope position.
The water pump reservoir and Create serial interface adapter are also located on this side.
Add Comment
