loading
Step 3: The Waterproof Enclousure
I was a bit unhappy with how thin the Waterproof case is, and wanted some protection of the iPad in case it gets blasted across the spa and hits a wall, so I added a silicon case to the iPad, cutting out access for the lower connector, as well as the Inductive charger.
The screen is sharp and clear, and you can control all functions.
I can't seem to reply to your comment about the heat management, so I'll just post here.<br> I have to disagree with your comparison of the water proof jacket to a wet suit. The water proof jacket is not a thermal barrier. The ipad will reach ambient temp which if left in the water will be the temp of the water. It will just take a little longer to get there due to the jacket surrounding it.<br> <br> The reason a wet suit insulates is because it allows a certain amount of water to remain between your body and the exterior of the suit. This allows your body to warm the water trapped within the wetsuit. With a wetsuit we're also talking about a temp far colder than your body's temp. Not the other way around where the temp would be higher than your body's temp.&nbsp; In that situation where you are in waters warmer than your core temp you would eventually overheat as the outside water radiated heat into the trapped water of the wetsuit.<br> Hope this helps you find a better heat management solution.&nbsp; Awesome work though, and thanks for sharing.
your bringing up some great points, I am not a diving expert, and the deepest I ever swam was my bathtub :)<br><br>I am just going to 'throw the ipad in the deep end' and see what happens<br><br>I have a tee shirt that says &quot;I void warranties&quot;<br><br>
What are you doing about heat management? As hot as a hot tube gets, it isn't very good for high end electronics.
That's a really good point, Here are the specs on the iPad<br><br> Operating temperature: 32&deg; to 95&deg; F (0&deg; to 35&deg; C)<br> Nonoperating temperature: -4&deg; to 113&deg; F (-20&deg; to 45&deg; C)<br> Relative humidity: 5% to 95% noncondensing<br> Maximum operating altitude: 10,000 feet (3000 m)<br><br>Since the hottest the water gets is about 100&deg; - 102&deg; the iPad is floating<br>slightly above that, but usually won't be submerged longer then a few seconds.<br>the waterproof jacket also adds a touch of insulation from the elements<br>and drops the temp down a few degrees (like a wetsuit shields the diver from extreme temperature)<br><br>Mostly the iPad will be sitting on the side of the Spa, or being held, I plan on testing it as thoroughly as I can (and will update the 'able' with details)<br><br><br>
Nice! But unless you are trying to cook your man-parts into oblivion I would suggest you turn the temp down. Would help keep you from cooking the iPad too :)
That's so nerdy, clever and awesome! :D <br>nice project
THANKS!! (Blush)<br><br>Jonathan
lol, asses of slain ice dwarves! :D cool instructable, might try it with my ipad!
Macgeek is totally right about the insulating properties of the protective case, especially if there is air between the iPad and the case. Heat from the hot tub will have to travel from the water to the case, then heat up a layer of air, which then heats the iPad.<br>That means the case probably works as a weak insulator, because it helps make the transfer of heat a little more inefficient and take a little longer.<br>Compare that to a wet suit, where your body produces the heat. You don't want that heat to be used to heat all the cold water around you, just the layer of water closest to your skin.<br>Once you've heated that layer, the neoprene suit acts as an insulator between the warm water on one side and the cool water on the other. More specifically, it's the air that is trapped inside the neoprene that makes the transfer of heat inefficient. In fact, the best insulation for diving is found in dry suits. Those are filled with a little bit of air and the diver's body stays dry. They work because, compared to water, air is not very good at transferring heat.<br>So assuming there is a pocket of air between the iPad and the protective case, what you probably have is an OK insulator, probably good enough to keep the iPad from heating up right away when it is submerged in hot water. But you wouldn't want it to be great insulator. As it operates, the iPad will generate heat and if that heat has nowhere to go, you'll have problems.<br>It sounds like Macgeek has the situation well in hand.
I was thinking about one thing to set the mood lighting. How about using the iSpa for controlling the lights in the room? Through bluetooth or wifi maybe?<br><br>Wonder if it would be easy programming an app for that if there isn't one already. Thanks for a great i'ble!
Hi Osquar,<br>Both my house and Spa are wired with Insteon (x10) remote controlled lights and controls, there are a great many Apps to control Insteon using wiFi.<br><br>I also can control it via a web interface.<br><br>No only can I turn on / dim the lights, I can remotely unlock the gate,<br>open the garage door, and (As my next 'i'ble will show)<br>Answer the front door.. All from my iPad<br><br>Jonathan<br>
I thought the iPads require a a more powerfull charging source. Or is that just the iPad 2? Great post gave me an idea for a different project with the 4s. Need something to do with it untill it is Jailbroken.
I charged it and used it, till it was empty then charged it again. <br>Works like a champ!<br><br>Jonathan
Does the touch-screen work through the plastic?
Yes, Very well!<br><br>Jonathan
About This Instructable
33,447views
26favorites
License:
More by macgeek:Alexa  (voice) Controlled RF Remote Zombie Finger Food Prop OOey Gooey Puke Worthy Zombie Shoes
Add instructable to:
