iSteadii 2.0 - Image Stabilizing Unit
I would like to introduce to you, the iSteadii .
Its task is to act as an adequate stabilisation unit, for a Compact point and shoot or a DSLR camera.
The principal is based on a floating buoy. The mass of the camera is equalised by the
counter-weight,  which is self locating. Therefore deadening fluctuations of movement.
Camera lenses today, come with options such as image stabilisation. Not only are these lens expensive, compared to their counters, they are not always the best bang for your buck.
This little unit should only set you back a few dollars, that's if you don't have the parts already laying around your house.
There is an iSteadii 1.0, yet this is a vaste improvement on that design. It deserves its own I'ble, which it may get at a later date.
By no means will this perform as well as a normal stabilising lens, but then again it does not cost as much.
On that note I give you iSteadii 2.0
Step 1What You Will Need
What You Will Need
Before you start you will need the following-
~ Utility Knife
~ Tennis ball
~ Sharpie
~ Pliers
~ Spanner to suit nuts
~ Tape
~ Threaded bolt  1 - 1 1/2 inches long or 25mm - 37.5mm with 1/4-20 thread type (Head type  irrelevant)
~ Nut to suit x 2
~ Washers x 2 (approx 3/4 - 1 inch)
~ Lead sinker (sphere type, atleast 8oz)
67 comments
1-40 of 67next »
May 31, 2011. 3:39 PMhelpme66 says:
Here's the best way to hold the thread.
Take a spare nut and cut through one of the corners (between two of the flats where the spanner goes) with a hacksaw. The nut should now look like a circle with a gap in it.
Screw the nut onto the thread and squeeze the nut against the bolt with a pair of visegrips.
This will grip well but won't damage the thread.
Jun 7, 2010. 4:02 AMSasquatchKid says:
Ill try it tonight because I'm 11 and i get paid by my school to take photos i get 50 bucks a week but saving up for a new laptop for editing an it's like 2000 dollars (i have 1000)
Jul 9, 2010. 12:12 PMjunits15 says:
wow thats a great pay for an 11 year old! I'm 15 and get paid $15 per hour to landscape common land, the max I've ever got in one week is $45! What kind of laptop are you looking at?
Jul 10, 2010. 3:51 AMSasquatchKid says:
Im looking at one of those fancy scmancy gaming computers (forgot lol)
Jul 10, 2010. 9:25 AMjunits15 says:
Alienware? those are awesome! I've had my eye on the m15X but i have no $ :) lol
Oct 22, 2009. 8:32 PMsockless says:
Under 18?
Why is it that people always underestimate the abilities of children?
I'm only 14 but I am perfectly capable of being able to use large power tools (e.g. lathes, mills, drill presses, diggers, mitre saws etc.) without injuring myself.
Apr 13, 2010. 3:24 AMbertzie says:
Mainly because children tend to overestimate their abilities.
Apr 13, 2010. 5:19 PMsockless says:
I guess so. It's also due to the legal system in the US of A. In New Zealand, we don't have to worry about people being sued, so in my 'ibles, I don't need to put a disclaimer, since you can't sue me :)
Oct 23, 2009. 12:29 AMThe Lightning Stalker says:
Nobody's insulting your intelligence. It's just another way of saying that if you screw it up, it's your bad. When we were that age, we had trouble assessing exactly what our abilities are, even though it didn't seem like it at the time. The same is still true, but certainly not to the same degree.
Dec 11, 2009. 11:53 AMjohnwwyatt says:
Thank you for this great idea.  Instead of the lead sinker, I used zinc plated BBs (0.177 caliber [4.5mm) steel airgun shot).  I filled the tennis ball about half full.  They roll around inside very well.  This saves the step of shaping the lead sinker.  You will need a funnel to pour them in but the hole can be slightly smaller.
Dec 24, 2009. 11:41 AMjohnwwyatt says:
I did see an improvement on low light shots, the BBs roll around in the tennis ball very easily and redistribute the weight nicely.  I made a couple as Christmas presents this year.
Jan 1, 2010. 2:48 PMSoupraok says:
So filling it with bbs works the same as putting a ball bearing, or a lead sinker, because i cant find a round lead sinker or ball bearing for the life of me.
Jan 1, 2010. 3:26 PMjohnwwyatt says:
Yes, the BBs are great and no extra work.
Mar 23, 2010. 8:32 PMwynddan says:
 i'm thinking of possibly doing this with the BBs but I have to ask, do you hear them rolling around as you move the camera? I ask b/c I use my dslr for video, and it might be pretty distracting to hear those sounds.
Mar 24, 2010. 8:33 AMjohnwwyatt says:
 No, if you move the camera slowly you do not hear the BBs rolling around, the tennis ball baffles most of the sound unless you shake it, I would think it should also work well when you are recording video, I did fill the ball to a little less than half full
Jan 1, 2010. 3:53 PMSoupraok says:
I know what Im doing tonight!!! Thanky!!
Feb 21, 2010. 9:46 PMsystemlayers says:
Thanks for this instructable.
I made mine and i have to say... It works!
It's not mind blowing or anything but seems to help a stop or two.
And in general i like the feel of the weight under my camera.
Helps with video as well.
I covered my tennis ball with electrical tape so it didn't look so ghastly though :p
Oct 16, 2009. 12:52 PMMike73 says:
Awesome idea. I really like this.
Oct 17, 2009. 1:57 AMMike73 says:
You're welcome.
I've been planning to make a bean bag for a couple of weeks now. With all the different lenses and a battery grip (awesome, it has a built in battery, so the original one can be used as a spare), a standard bean bag won't do. So I'm thinking about some sort of adjustable bean bag with a couple of segments and velcro. I'll post it as soon as I get to actually realise my plan.
Jan 3, 2010. 9:07 PM01new says:
Hi there!
Does this works for any type of camera?   i have a small camera so i wanted to ask first..    Thanks
Jan 16, 2010. 8:40 AMmianne says:
This should work with any camera with a standard tripod mount, from a $20 point and shoot or a $2500 dSLR. (Though the latter will probably already have image stabilization built into the body.)
Dec 12, 2009. 5:57 AMohgood says:
 very cool. going to try this today. :) thank you !
Nov 1, 2009. 7:08 PMbhunter736 says:
Great idea!  Thanks for sharing.
Oct 31, 2009. 5:07 AMlemminggenocide says:
why not use a gimble?
Oct 25, 2009. 10:40 AMdbbd says:
 I don't get it. So making your camera heavier makes it more steady?
My camera is heavy enough, how making it even heavier improves stability?
Oct 16, 2009. 3:17 PMstefan says:
A dumb question for sure: I take it the lead weight rolls around inside the tennis ball, and that's what you mean by 'self locating'? How is that better than having it in a fixed position? Does having the weight more 'down' help?
Oct 22, 2009. 3:59 PMcraftsman says:
when you bring the center of gravity of an object down it is more stable, but you're right a fixed position would almost undoubtedly be better
Oct 23, 2009. 2:20 PMcraftsman says:
oh you mean like on a table or something like that?
I was referring to the use of a tripod as fixed position
Oct 24, 2009. 9:53 AMskidoo says:
Don't you mean a good tripod with a 9-pound weight hanging from its center axis trumps everything? ;-)
Oct 23, 2009. 9:19 PMcraftsman says:
yea nope i didn't I just surmised from the pictures.. :)
1-40 of 67next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
89
Author:Lftndbt
I work in a D.i.Y style superstore. I am not sure if that is a good thing or not, but it certainly perpetuates my interest in such areas. I enjoy high powered devices of any kind. I do not give...
more »
