Its task is to act as an adequate stabilisation unit, for a Compact point and shoot or a DSLR camera.
The principal is based on a floating buoy. The mass of the camera is equalised by the
counter-weight, which is self locating. Therefore deadening fluctuations of movement.
Camera lenses today, come with options such as image stabilisation. Not only are these lens expensive, compared to their counters, they are not always the best bang for your buck.
This little unit should only set you back a few dollars, that's if you don't have the parts already laying around your house.
There is an iSteadii 1.0, yet this is a vaste improvement on that design. It deserves its own I'ble, which it may get at a later date.
By no means will this perform as well as a normal stabilising lens, but then again it does not cost as much.
On that note I give you iSteadii 2.0
Remove these ads by
Signing UpStep 1What You Will Need
~ Utility Knife
~ Tennis ball
~ Sharpie
~ Pliers
~ Spanner to suit nuts
~ Tape
~ Threaded bolt 1 - 1 1/2 inches long or 25mm - 37.5mm with 1/4-20 thread type (Head type irrelevant)
~ Nut to suit x 2
~ Washers x 2 (approx 3/4 - 1 inch)
~ Lead sinker (sphere type, atleast 8oz)
Take a spare nut and cut through one of the corners (between two of the flats where the spanner goes) with a hacksaw. The nut should now look like a circle with a gap in it.
Screw the nut onto the thread and squeeze the nut against the bolt with a pair of visegrips.
This will grip well but won't damage the thread.
Why is it that people always underestimate the abilities of children?
I'm only 14 but I am perfectly capable of being able to use large power tools (e.g. lathes, mills, drill presses, diggers, mitre saws etc.) without injuring myself.
I write a few I'bles, many with some dangerous aspects. As an Author you have to understand, that if a minor follows your instructions, hurts themselves but DID NOT REALISE they might hurt themselves (as silly as that sounds), you the author are indeed liable.
There are several documented cases where not only minors but adults have had charges laid for mis-guiding instructionals.
I am just being pre-cautious. I do not expect an 18, 17, 16, 15, 14, 13 or even 12 year old would hurt/have problems with any of these steps.
I made mine and i have to say... It works!
It's not mind blowing or anything but seems to help a stop or two.
And in general i like the feel of the weight under my camera.
Helps with video as well.
I covered my tennis ball with electrical tape so it didn't look so ghastly though :p
I've been planning to make a bean bag for a couple of weeks now. With all the different lenses and a battery grip (awesome, it has a built in battery, so the original one can be used as a spare), a standard bean bag won't do. So I'm thinking about some sort of adjustable bean bag with a couple of segments and velcro. I'll post it as soon as I get to actually realise my plan.
Does this works for any type of camera? i have a small camera so i wanted to ask first.. Thanks
My camera is heavy enough, how making it even heavier improves stability?
Remember you need to tilt the camera up,down,left,right and all diagonals... A fixed position will always want to drag the camera back to level, putting strain on your wrists, actually making you shake more...
I was referring to the use of a tripod as fixed position
He is referring the the counter weight rolling inside the tennis ball...
A tripod trumps everything always for a "fixed position".
If i'm doing landscapes, HDR or astrophotography, my camera is fixed to a tripod.
