Step 2Getting started
Mark with your sharpie a line slightly wider than your sinker.
WARNING- The next proceedure can be dangerous, if done in a rush or carelessly. Please take your time. If you are under 18 I strongly suggest you get Mum or Dad to assist. Removing the dags from the lead is easy with a sharp utility knife, yet some pressure is required.
I assume no responsibility for you injuring yourself, from following these instructions. This is a guide only and it is your responsibility, to not attempt this, if you are not capable.
Use your utility knife to cut open the ball along the line.
Before we insert the sinker we need to take the dags from the lead mold off, so it resembles an almost perfect sphere.
Once you have done this insert the lead sinker.
Why is it that people always underestimate the abilities of children?
I'm only 14 but I am perfectly capable of being able to use large power tools (e.g. lathes, mills, drill presses, diggers, mitre saws etc.) without injuring myself.
I write a few I'bles, many with some dangerous aspects. As an Author you have to understand, that if a minor follows your instructions, hurts themselves but DID NOT REALISE they might hurt themselves (as silly as that sounds), you the author are indeed liable.
There are several documented cases where not only minors but adults have had charges laid for mis-guiding instructionals.
I am just being pre-cautious. I do not expect an 18, 17, 16, 15, 14, 13 or even 12 year old would hurt/have problems with any of these steps.
