3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
iSteadii 2.0 - Image Stabilizing Unit
Step 4Inserting and Tightening Up
We now need to insert the bolt and tighten it.
This can be a little tricky.
Insert the first washer leaving the other outside the wall.
We now need to tighten the bolt.
This is where the pliers, spanner and tape come in.
Take your tape and wrap it firmly around the exposed thread. Put enough on it, so the pliers will not damage it when gripped.
Grip the taped thread with some force and use the spanner to tighten the nut.
Not much pressure is required to sandwich the wall, so you should not damage the thread.
We're almost there!!
2 comments
May 31, 2011. 3:39 PMhelpme66 says:
Here's the best way to hold the thread.
Take a spare nut and cut through one of the corners (between two of the flats where the spanner goes) with a hacksaw. The nut should now look like a circle with a gap in it.
Screw the nut onto the thread and squeeze the nut against the bolt with a pair of visegrips.
This will grip well but won't damage the thread.
Oct 22, 2009. 4:25 PMThe Lightning Stalker says:
The proper way is to use 2 spanners, or better yet, socket wrenches.
Oct 23, 2009. 12:24 AMThe Lightning Stalker says:
Make a small hole on the bottom? I dunno, sorry. I don't understand if you're trying to do all this using just the one hole or what exactly. If you're gripping the nut with pliers through the skin of the ball, that would be more than enough to protect the threads. I would recommend a large wing nut in that case. Much easier to grip in a situation like that
Oct 23, 2009. 9:10 PMThe Lightning Stalker says:
There's nothing wrong with your nylon lock nut either.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
94
Author:Lftndbt
I work in a D.i.Y style superstore. I am not sure if that is a good thing or not, but it certainly perpetuates my interest in such areas. I enjoy high powered devices of any kind. I do not give...
more »
