What's a fire piston anyway?
A fire piston is an amazing little tool that's been around for hundreds of years, unfortunately due to the invention of the common match its popularity diminished and it almost dissapeared. It is a piston and cylinder that works like a diesel engine using compression to cause a piece of tinder to heat up rapidly and turn into a coal. Wikipedia explains it better than I do so if you're really interested just click here for the full history.
The most important part about getting one of these working seems to be the char cloth or char string which is used as the tinder, don't be fooled by other videos online its almost impossible to light just regular balls of rolled up tissue paper. Charcloth is a cotton based material that is heated in an oxygen deprived container until certain gases etc are released afterwhich the remaining material turns to an ember really easily. Another characteristic of char cloth is that the ember grows when it is blown on (so wind actually helps you!)
Making a fire piston without having char cloth will make you go crazy, chances are you'll have a working piston but won't know it because your using the wrong tinder. Make char cloth first!!!
Materials
5" or more of 1/4" brass rod
4" 1/8th Threaded brass pipe nipple
1/8 Threaded brass cap
1/4" OD 1/8" ID 1/16 Cross section rubber o-rings aka -006 size
2 part liquid epoxy (Jb Weld, Cold Weld etc)
Wooden cabinet knob (or you can make your own)
Wooden Broom Handle or suitable wood for turning*
Cotton T-Shirt (Optional for making char cloth)
Tin can that seals (Optional for making char cloth)
Tools
Drill Press & Drill Bits
Lathe*
Triangle File
Hacksaw
*Not all the tools/materials are necessary just to get a working piston. Instead of using a lathe you could file the o-ring groove by hand for example. The wooden sleeve made from the broom handle is optional as its purely cosmetic.
**All the slides were made with Google Sketchup, playing around with the styles gave it the illustrated look and it reminded me of a kids book so I ran with it ;)
Remove these ads by
Signing UpStep 1Cut Raw Brass Rod
Just to add my two cents: I've found that wetting the char cloth with turpentine (not mineral spirits - real turpentine) then allowing them to air-dry gave me a much more flammable char cloth. I had the darndest time getting a fire started before this treatment, but now they reliably catch a spark and easily heat up enough to ignite tinder.
In the woods, I don't want to be relying on something that sometimes works. But every fire starting technique only works sometimes and that is why it is wise to have a variety of means to start a fire at hand. I already carry matches, tinder, flint, char cloth, cigarette lighter and a magnifying glass ... it wouldn't hurt to add a fire piston, too.
To those who question the wisdom of a fire piston, allow me to point out that they are very light weight, very simple to operate and work even when your fingers are too cold to deal with matches or a lighter.
That last part could be important.
Hint: load the char cloth in the fire starter before you need it. Then, if you have the rest of the fire starting materials gathered, you are only a slap or two of the piston away from a fire.
@Shootin Wizard
http://en.wikipedia.org/wiki/Drill_bit_sizes
As for the narrow end it is 1/2 inch diameter and rounded on the end (rounding helps a lot) but if you try to learn how to make it work with tinder fungus as tinder in one night (many many many strokes one right after another for hours) it will make your hands VERY sore (I still have some small bruised spots after 2 weeks).
With this new optimized piston it is much easier to strike it though.
Also I have polished the cylinder very smooth, I think this will help with a lot of the problems people have with any fire piston and will likely make o-rings last longer.
I made a test piston from stainless steel rod, it worked pretty good.
I would definitely recommend storing the char cloth/string in an air tight container if at all possible anyway just to limit the exposure to moisture.
If you build one and use it out there please comment about your experience!
Good luck!
any suggestions? i have put alot of time into it this weekend and it is getting frustrating. thanks for the good instructable though!
The first thing that comes to mind is whether your o-ring is too big in the first place?
Secondly, on your piston the angle of the piston where the oring sits may not be steep enough and is allowing your oring to slide up too far? (see attached image, sorry for the quality I only had mspaint to work with).
Another possibility is that you've somehow scored the inside wall of the tubing with the piston head and that is preventing a good seal.
This may be a stupid question but you are using vaseline or chapstick to lube the o-ring right?
You will need compression throughout the entire stroke or there will be no heat. If its sealed correctly you shouldn't even be able to get the piston down quite all the way (say 95% but not 100% of the way).
As for the frustration, I know, I've been there and I feel your pain lol. It took me more than just a weekend to get my first one going, probably spent 60hrs total. My hopes of this instructable were to help other people avoid that frustration ;)
Just think though how hard it must have been for the jungle tribes that made these with wood or bamboo and used string as the o-ring. Even with detailed instructions, better materials, and modern machinery these pistons are still tricky to make!
Good luck and if you figure out the issue please post back so other people can benefit.
Sorry to came in the conversation.
I ve built a piston, I guet in same diferente way.. in the rod I left a gap, Insted make like you said. But I press the road,...he road came back, pull back, the 0 ring its good,its seal, I have nice charcol(Because I ve try with flint stone,by stricking it) BUT I CAN NOT MAKE A FIRE......
I HAVE TO SAY , IN SAME OPORTUNITY I VE SEE SMOKE IN THE PIPE,BUT NEVER FIRE IN THE CHARCOL.
do you have any idea.???
could I fill a bit the hole wich I ve made in the rod(piston) in same way? like expoxy, could help?
thanks for help.
i am going to try with a new section of brass since i had to buy about 3 feet.
I am also going to try some different techniques when drilling and cutting the O-ring Groove. and when flaring the nipple.
also, i am using 3/16th inch O-rings, i also bought 1/4 and 5/16th but the smaller ones fit the best and there was no 1/8th inch at any of the stores i visited.
Will keep fiddling and get back to you, thanks for your help
p.s yes im using vaseline
One question for you. I believe i followed the instructions very well for both the char rope/paper and the piston. After testing with several materials and plunging my heart out I only got one piece of char rope to glow. The piston can be pushed in and then comes back out 3/4 of the way by itself. I was hoping that this was going to be easier than rubbing 2 sticks together. Any thoughts on what could be done differently?
1) Even though you're getting a good seal your "throw" may not be long enough, if you followed the instructable though it should be ok. The reason I state this is if the throw isn't long enough you wont be building up enough pressure therefor not creating enough heat. Not having enough epoxy in the cap could also affect total pressure.
2) The char string/cloth isn't up to par, this as you say though probably isn't the case.
3) You've contaminated the char string/cloth. This is probably the most likely cause, oils from your fingers or from the vaseline used to lubricate the o-ring can render char string/cloth useless.
4) When in doubt add more lube to the o-ring ;) Not so much that it contaminates the char material mind you.
If you get it working reliably please post back with what you did to fix it.
Good luck!
If you meant using a different metal for the rod then the reason I used brass is that this is the material I found that works the best. Its easy to cut and shape and comes with a nice smooth finish. Steel is very hard to work with in order to get the o-ring groove and channel for containing the tinder. Aluminum is a little too soft and I found the stock to be too rough.
I spent weeks working on this and even ordered a ready-made one just to see if I could learn from their design. This instructable shows the only method I found that actually yielded a repeatable result, after the first successful one I made 5 more exactly the same way and they all worked first try.
Hope this helps.
http://www.youtube.com/watch?v=a8BY6AbHL9w
