install sound deadening material in your car! (fake dyna mat) to make your car sterio sound awesome! by josh
ever see something that's all packaged nicely and sold for an exorbitant sum and think to yourself. "I could make that!" or "that's just _______ in a shiny package!" that's what I did one day when looking for sound deadening material for my car. Dyna mat is a really great product that really cuts down on road noise, body noise/reverb  from your awesome system and other annoying sounds in a car. The thing is that it's expensive! I realized that dyna mat is actually sold at Home Depot for a completely different purpose! it's used as a flashing material on house roofs!
the HomeDesperate sells the stuff for 20 bux a roll vs dyna mat's $100!
Step 1: First step peel it off the roll.
I'm a little slow sometimes so it took me a minute to figure out how to get it off the roll. Now is also the time to make sure your surface is clean!
Ranie-K says: Nov 27, 2012. 1:18 PM
Great idea! Probably good for silencing a desktop computer case, too! Who (if any) has tried sticking this stuff all over the inside of a desktop computer case?
dchall8 says: Nov 28, 2012. 4:45 PM
If the fan is making noise, you likely need a new fan. If the case is vibrating for some reason, any putty material will damp the vibration. You do not need to cover the entire case. I keep some office supply putty handy to stick paper to various objects when I need to . Start putting putty in quarter-sized pieces in various patterns around the outside of the case. If you get no improvement, then something else is vibrating.
nathangill says: Nov 27, 2012. 6:46 PM
I'd be really careful about this - even though the fans move new air through the case, the metal case should still be treated as an important heat sink. Give it a shot, but keep an eye on the temp inside the case.
rimar2000 says: Nov 27, 2012. 3:06 PM
I improved a bit the noise in my desktop sticking pieces of mop in the inner. The mop absorbs some of the noise made by the coolers.
Ranie-K says: Nov 28, 2012. 7:04 AM
I've stuck cork and sound foam on the inside of my computer case with a tiny bit of success, but this stuff is probably much better, since it is heavy and uses that instead of diffusing/reflecting. About the heat-sink bit that nathangill mentioned: Yes, the case is a heat-sink, and whatever you stick to it on the inside will not affect air-stream on the outside of the case (where air temperature should be cooler than on the inside), so I wouldn't be worried, since the PSU (that is a major heat source) is bolted to the case and should therefor transfer much heat easily.
caitlinsdad says: Nov 28, 2012. 3:39 AM
I've used that stuff to repair roof leaks. The mastic or thick black layer may be made of some tar-like product. When exposed to extreme heat, it will get gooey and offgas a smell if you use it in an enclosed area. Once you stick it, it will be difficult to remove.
josh (author) says: Nov 28, 2012. 6:29 AM
Yea. That is a good point. It is difficult to remove. Generally people who install it should not expect it to remove it. (Please dont install it on amazing one of a kind classic cars... Do it for the kids) it is a rubberized asphalt. I've installed dynamat and aside from logos printed on the product it appears to be identical. As for off-gassing it seems not to be a problem. I live in the Desert Southwest and this stuff seems to hold up well. My new carpet, headliner, glue, vinyl seats and rubber seals off-gas much more than this stuff, and this is sealed between a body panel and the aluminum backing.
caitlinsdad says: Nov 28, 2012. 6:44 AM
Nothing more intriguing than that new car smell. I think they have that as an air freshener scent.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
