Introduction: Introduction to Electricity
This breadboard is designed to introduce 11-12 year old students to the most elementary laws of electricity (such as, e.g. a simple electrical circuit, simple switches, electrical loads, series and parallel circuits of electrical loads and batteries) by the means of simple experiments. There is a comprehensive teaching guide in German attached (note: some images may not be shown properly by internet browsers; download the file to your computer and opening it offline may solve that problem) .
CAUTION:
ELECTRIC CURRENT CAN CAUSE SERIOUS INJURY! ALL EXPERIMENTS MUST BE SUPERVISED BY A RESPONSIBLE ADULT! USING THE BREADBOARD IS AT YOUR OWN RISK!
Step 1: Before You Can Start Experimenting - Manufacturing the Breadboard
Step 2: Experiment 1 - a Simple Electrical Circuit
For this first experiment, a common light bulb (E10), a 1.5V-battery (AA) and wire are required. The goal is to turn the light bulb on.
What needs to be done? Try different ways!
CAUTION:
Step 3: Experiment 2 - Electric Conductors and Electric Non-conductors
For this experiment, a common light bulb (E10), a 1.5V-battery (AA), wire (as for the first experiment) and two wires with alligator clips are required. The latter must be connected through different objects as shown in the photo - such as, e.g., wooden and plastic rulers, scissors, keys, etc. The goal is to turn the light bulb on.
What kinds of material makes it shine, i.e. is an electric conductor, and which are non-conductors? Try as many as you can!
CAUTION:
Step 4: Experiment 3 - Simple Electric Switches
What needs to be done with a push-to-break switch, and what with a push-to-make switch? Compare both kinds of switches with electric switches on some of your devices at home (NEVER MANIPULATE OR OPEN THEM) - such as, e.g., the keys of a computer keyboard, the switch for your door bell and for the light in your room.
CAUTION:
Step 5: Experiment 4 - Series and Parallel Circuits of Electrical Loads
In what ways can the two light bulbs be connected with the battery? Compare the brightness of the light bulbs in series and parallel circuits!
CAUTION:
Step 6: Experiment 5 - Series and Parallel Circuits of Batteries
Think of the two ways both batteries can be connected (remember experiment 5: two ways to connect to light bulbs) and try to predict what way will lead to the goal! Then try it out and compare the outcome to your prediction!
CAUTION:
Step 7: This Is Where the Fun Begins - Building the Electric "wire Loop Game"
Before manufacturing, try to understand the schematic shown in the second photo. If you need help, compare the product and the schematic as shown in the fourth photo!
For the manufacturing, you need a board (as indicated in the datasheet, see step 1), a battery clip for two 1.5V batteries (AA or AAA), a two-way switch (single pole, single throw), a piezoelectric speaker, two light bulbs (E10) and corresponding sockets (compare the datasheet in step 1), wire and cable end sleeves. The latter are immersed into the board and used for the soldering of the wires (see the third photo for details).
CAUTION:
DRILLING, SOLDERING AND ELECTRIC CURRENT CAN CAUSE SERIOUS INJURY! MANUFACTURING MUST BE SUPERVISED BY A RESPONSIBLE ADULT! USING THE GAME IS AT YOUR OWN RISK!
Step 8: This Is Where the Fun Begins - Building the Electric "straight Shot Game"
For the manufacturing, you need a board (as indicated in the datasheet, see step 1), a battery clip for two 1.5V batteries (AA or AAA), a two-way switch (single pole, single throw), a piezoelectric speaker, one light bulb (E10) and corresponding socket (compare the datasheet in step 1), wire, five eye screws (M3, diameter of the "eye" 10mm) and cable end sleeves. The latter are immersed into the board and used for the soldering of the wires (see the third photo for details).
CAUTION:
