Iphone Controlled Led Without a Computer or Internet
2,936
41
5
Posted
Introduction: Iphone Controlled Led Without a Computer or Internet
I build a small webside running on the arduino with ethernet I/O using HTML and a little bit of css.
When sending a HTTP request the script reads the request and gets a command from it.
You don't need internet, only a working network and a computer of smartphone connected to the same network.
Step 1: The Parts
Parts: 1 arduino, 1 ethernet shield, or a Sparkfun Pro Ethernet (not for sale anymore....) 1 LED connected to digital pin 9 and GND, 1 network-cable working network
Step 2: The Circuit
easy:
just plug the led (+) into the digitale pin 9 and the short one to GND.
And connect the arduino to the network with a networkcable.
Step 3: The Code
just upload this code to the arduino:
/* IPhone controlled LED
Turns on and off a LED connected to a digital pin, via a computer or
IPhone (or even a android device) without using internet.
combined examples:
Examples > Ethernet > Webserver and Examples > Digital > BlinkWithoutDelay
The circuit:
* LED attached from pin 9 to ground.
* EthernetShield using pins 10,11,12,13.
created mar 2013
by Floris
floris (at) deboktor.nl
This example code is in the public domain.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = {
  0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192,168,30,178); //choose a IPadress so you can easily find it on your computer
EthernetServer server(80);
String currentLine = "";
char Command[100];
int page = 2;
int prevpage = page;
long previousMillis = 0;
long interval = 500;
int ledState = LOW;
boolean PageUpdated = false;
int LedPin = 9;
void setup() {
  pinMode(LedPin, OUTPUT);
  currentLine.reserve(256);
  Ethernet.begin(mac, ip);
  server.begin();
  digitalWrite(LedPin,LOW);
void loop() {
  EthernetClient client = server.available();
  if (client) {
    boolean currentLineIsBlank = true;
    boolean ValidCommand = false;
    int i = 0;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        currentLine += c;
        if (!ValidCommand){
          Command[i] = c;
          i++;
        if (c == '\n') {
          currentLine = "";
        if ( currentLine.endsWith("HTTP/1.1")) { //line format is like: GET /?s=1 HTTP/1.1 or GET /favicon.ico HTTP/1.1
          ValidCommand = true;
          if (Command[5]-'?'==0){ //if the 5th karakter is ?
            if (Command[6]-'s'==0){ //then a s
              prevpage = page; //to prevent giving a strange command
              page = Command[8]-'0';//after the ?= is the actual command
              if(page!=1 && page !=2 && page!=3){ //1 = on, 2 = of, 3 = flashing
                page = prevpage;
        if (c == '\n' && currentLineIsBlank) {
          delay(10);
          client.print("<!DOCTYPE HTML>\n");
          client.print("<HTML>\n<HEAD>\n");
          client.print("<TITLE>led-online</TITLE>\n");
          client.print("<meta name='viewport' content='user-scalable=yes, width=device-width'>");
          client.print("<style type='text/css'>\n");
          client.print("body {\n background-color: white; \n color: #222; \n font-family: Helvetica; \n margin: 0; \n padding: 0\n }\n");
          client.print("div#button_On {\n background-color: blue; \n border-bottom: 1px solid #666; \n color: #222; \n display: block; \n font-color: black; \n font-size: 14px; \n font-weight: bold; \n padding: 10px 0; \n text-align: center; \n text-decoration: none\n }\n\n");
          client.print("div#button_Off {\n background-color: #ccc; \n border-bottom: 1px solid #666; \n color: #222; \n display: block; \n font-color: black; \n font-size: 14px; \n font-weight: bold; \n padding: 10px 0; \n text-align: center; \n text-decoration: none\n }\n\n");
          client.print("a {\n text-decoration: none;\n }");
          client.print("\n </style>\n");
          if ((page!=0)&&(!PageUpdated)){//1 sec after a command refresh the page
            client.print("<META HTTP-EQUIV='refresh' CONTENT='1; URL=/'>\n");
            PageUpdated = true;
          else{ //normally once everyy 10 sec a page update
            client.print("<META HTTP-EQUIV='refresh' CONTENT='10; URL=/'>\n");
          client.print("</HEAD>\n");
          client.print("<BODY>\n\n");
          client.print("<a href='/?s=1'>\n");
          if (page==1){
            client.print("<div id='button_On'>");
          else{
            client.print("<div id='button_Off'>");
          client.print("LED ON");
          client.print("</div>\n");
          client.print("</a>\n");
          client.print("<a href='/?s=2'>\n");
          if (page==2){
          else{
          client.print("LED OFF");
          client.print("<a href='/?s=3'>\n");
          if (page==3){
          else{
          client.print("LED FLASHING");
          break;
        if (c == '\n') {
        else if (c != '\r') {
          currentLineIsBlank = false;
    delay(1);
    client.stop();
  switch (page){
  case 1:
    digitalWrite(LedPin,HIGH);
    break;
  case 2:
    break;
  case 3:
    digitalWrite(LedPin, ledState);
    if(millis() - previousMillis > interval) {
      previousMillis = millis();
      if (ledState == LOW)
        ledState = HIGH;
      else
        ledState = LOW;
    break;
Step 4: Finally
go the the IP adres asigned in the code on a smartphone or computer connected to the same network as the arduino.
a 3 button page will appear.
Just click on one of the buttons and see whats happening......
    • Trash to Treasure
      Trash to Treasure
    • Microcontroller Contest
    • Pocket-Sized Contest
    5 Comments
    Hello!
    Hope all is well.
    This is Jim from WIZnet.
    As you might already know, WIZnet is well known for its hardwired TCP/IP chip and its W5100 being used in Arduino’s official Ethernet shield.
    We also partnered with ARM as mbed silicon partners, and plan to offer more platforms for makers.
    To help makers grow the open source hardware community, we are having an IoT design contest, titled ‘Curation is Creation.’
    Come up with any IoT project idea and take advantage of this contest since we’re offering our ARM mbed-enabled WIZwiki-W7500 platform & WizFi310 shield at sample pricing.
    To start, register your account at www.CyberMakerSpace.com
    This contest will be held from May to August, with 16 prizes totaling $15,000.
    We expect and hope that many makers, including members of WIZnet Museum www.wiznetmuseum.com, will participate and share their knowledge.
    As this is a contest for the open source community, WIZnet wants to give back the power of the vote to all participants.
    Hence, you can vote and provide feedback of other projects from September to October.
    More details of the contest are available at www.CyberMakerSpace.com and technical questions are answered at https://forum.wiznet.io/
    Hopefully, you’ll find interest in this contest and we look forward to your next creative IoT project!
    Sincerely,
    Best Regards,
    Jim
    This is good.
    I have been searching some application references in which WIZnet solution is applied, and found your project using Ethernet Shield.
    In the Ethernet Shield WIZnet's W5100 chip is embedded.
    If you are O.K. I'd like to post this article in WIZnet Museum (http://wiznetmuseum.com) for others.
    mr floris
    this is the section of your code
              delay(10);
              client.print("<TITLE>fpoels iPhone Controlled LED wo computer or internet</TITLE>\n");
              if( led_ == OFF_ ){
                client.print("div#button_On  {\n background-color: lime; \n border-bottom: 1px solid #666; \n color: #222; \n display: block; \n font-color: black; \n font-size: 42px; \n font-weight: bold; \n padding: 32px 0; \n text-align: center; \n text-decoration: none\n }\n\n");
                client.print("div#button_Off {\n background-color: black; \n border-bottom: 1px solid #666; \n color: #222; \n display: block; \n font-color: lime;  \n font-size: 42px; \n font-weight: bold; \n padding: 32px 0; \n text-align: center; \n text-decoration: none\n }\n\n");
              if( led_ == ON_ ){
                client.print("div#button_On  {\n background-color: red; \n border-bottom: 1px solid #666; \n color: #222; \n display: block; \n font-color: black; \n font-size: 42px; \n font-weight: bold; \n padding: 32px 0; \n text-align: center; \n text-decoration: none\n }\n\n");
                client.print("div#button_Off {\n background-color: black; \n border-bottom: 1px solid #666; \n color: #222; \n display: block; \n font-color: red;  \n font-size: 42px; \n font-weight: bold; \n padding: 32px 0; \n text-align: center; \n text-decoration: none\n }\n\n");
    create this effect when button_Off  =>   ON (black letter lime background)   when is button_On  =>     ON  (lime letter black background)
    and
    create this effect when button_Off  =>   OFF (black letter red background)   when is button_On  =>     OFF (red letter black background)
    it is all on the "div#button_Off  line - again if i change the colors back to #ccc and black IT WORKS - if o modify IT DOESNOT
    another piece of info i have a iphone 3S with OS 4.2.1
    this is weird....
    mr floris - i finally got your fabulous example working - i do not have any knowledge at all of any of this and would like to modify the code so when the button is off has different color - i changed the value from #ccc to black and the code does not run at all - changed it back to #ccc and it does run - what would make that to happend ?
    Strange....
    Did you use 'black' or '#000' ?
    Should work both but you never know.
