then i came across this on http://forums.vnunet.com/thread.jspa?threadID=105769&tstart=210:
user: jd858us
Re: ipod Nano hold switch remains on
Posted: 25-Apr-2007 22:15 in response to: Colinzzz
I had the same problem (stuck on hold and the switch was obviously faulty) with an out-of-warranty 2GB nano. It wasn't worth the cost of the repair so I had nothing to lose by trying a workaround. Here's what I did. After taking the cover off and removing the screws that hold the main board to the case, the hold switch's contacts were visible on the front of the board. There are three contacts (very tiny) but all the switch does is connect the center to either of the end contacts making the hold on or off. All I had to do was roll up a speck of tin foil and wedge it between the center contact and the "on" contact. Then I locked it in place with a couple drops of clear nail polish. No more "hold" function, but it works great!.
So, I opened the thing up. ( You can learn how to do this here: http://www.powerbookmedic.com/free-ipod-manual/ipodnano.pdf )
I couldn't get the tinfoil fix to work, so i just soldered those little switches together (on the back of the logic board where it says "hold switch contact area" you'll see three little metal patches - that's where to solder). And it worked again perfectly! Like the post said, no more hold function, but it would play....so what to do about the hold? How could I put it in my pocket or bag?
Remove these ads by
Signing UpStep 1Hey, what about that altoids tin?
THANKS! The hold button on my nano was stuck in the hold position.
I opened the case and unscrewed the 2 small screws. The hold button was unresponsive even after I moved it back and forth. So I pulled the hold switch area off. Placing tin foil over the 3 little switches underneath...the Nano came to to life w/o holding. So I soldered those together and it worked!
No HOLD feature anymore, but it works perfectly now. Thanks again
You need only attach the wire to the center point and to the outer point. Those points are silver color - not copper - and they are very small but easy to get to.
Thanks for the great tip.
Great instructable by the way! Thanks :)
