Joining My PC Gaming Step by Step | DIY | by Scaly Dragon
1,173
19
Posted
Introduction: Joining My PC Gaming Step by Step | DIY | by Scaly Dragon
This is another of my hobbies that I love to do other than play video games and do crafts I hope you like it or find it useful .
Step 1: Packages Delivered
the next thing we will see will be the characteristics of each component.
Step 2: Step by Step Video
Step 3: Graphic Card Gigabyte GeForce GTX 960 Gaming G1 WindForce 4GB GDDR5
Specifications:
· Chipset GeForce GTX 960
· Core Base Frequency / Boost clock : 1266/1329 MHz in OC mode
· Base / Boost clock : 1241/1304 MHz (standard : 1127/1178 )
· Memory Frequency 7010 MHz
· 28 nm processing technology
· Memory 4 GB
· 128-bit Memory Bus
· Bus Type PCI- E 3.0
· Type GDDR5 Memory
· DirectX 12
· OpenGL 4.4
· PCB Form ATX
· Multi View 4
· E / S Dual -link DVI -I * 1 / DVI - D * 1 / * 1 HDMI / Display Port * 3
· Maximum digital resolution 4096 X 2160
· Analog Max Resolution 2048 x 1536
· Card size H = 43 mm , L = 295mm , W = 114 mm (without stand )
· Power requirements 400W ( one and one 6-pin external power connectors 8-pin )
Step 4: Memory RAM Kingston HyperX Savage DDR3 1600 PC3-12800 16GB 2x8GB CL9
Specifications:
· Internal memory 16GB
· Internal memory type DDR3
· Memory clock speed 1600 MHz
· Component for * PC / server
· Memory form factor 240 - pin DIMM *
· Memory layout (modules x size) 2 x 8GB
· CAS Latency 9
· PC3-12800
· Memory voltage 1.5 V
· Memory unbuffered
· Product Color Red
· XMP
Step 5: Motherboard MSI Z97 Gaming 5
Characteristics:
· Audio Boost incredible sound with 2 driven by Creative Sound Blaster Cinema 2
· Audio Power USB
· The fastest shot the lowest delay Killer ™ E2200 Game Networking
· Push your SSD to the border with M.2 & SATA Express
· Enjoy your peripherals with full port Gaming
Increases your FPS with MSI GAMING APP, which combines the best of motherboards and graphics cards MSI
· Prove your gaming skills in the world with 6 free months of XSplit Gamecaster
· Enabled steamos
· Components Military Class 4
· Maximum stability with Pro-Guard technology
· OC Genie 4
· Click BIOS 4
· Optimized for multiple graphics cards (SLI and CrossFire)
· Take control with the Command Center & Live Update 6
Specifications
· CPU
or CPU Support 4th and 5th generation Intel ® Core ™ and Intel ® Pentium ® and Celeron ® processors
or Socket LGA 1150
· Chipset
or Intel® Z97 Express Chipset
· GUI
or 3 x PCI-E 3.0 x16
or AMD CrossFireX ™ support
NVIDIA® SLI® or support
· Display Interface
or HDMI
or DVI
or D-Sub
or (requires CPU graphics)
· Memory Support
or 4 DIMMs, dual channel DDR3-3200 (OC)
· Slots
or 4 x PCI-E x1
· SATA / M.2
or 6 x SATA 6Gb / s
M.2 or 1 x 10 Gb / s (SATA-E opt.)
· SATA RAID
or RAID 0, 1, 5, 10
· USB
or 6 x USB 3.0
or 8 x USB 2.0
· LAN
Killer ™ E2205 or gigabit LAN
· Audio
or 8 channel HD Audio Boost 2 with Creative SBC 2
Step 6: Heat Sink Cooler Master Hyper T4 - Fan / Cooler
Characteristics:
· 4 Heat - foot copper and aluminum foils.
· 120x120x25mm PWM fan . 600 ~ 1800RPM . 24 ~ 70CFM . ~ 15.1 31.6dBA .
· Snap -on brackets for easy installation and cleaning fan .
2011/1366/1156/1155/775 Compatible with Intel and AMD FM1 / AM3 + / AM3 / AM2 .
Specifications:
· Compatibility
or 775/1155 / 1156/1366 / 2011
or AM2 / AM3 / AM3 + / FM1
· Material Heat -pipes copper / aluminum sheets
· Fan 120x120x25mm
· Bearing Type Rifle Bearing
· Airflow (CFM ) 24 ~ 70 CFM
· Speed (RPM ) 600 ~ 1800 RPM
· Noise level dB ( A) 15.1 ~ 31.6 dBA
· PWM control
· Dimensions
or W x H x 131.6mm x 152mm x 72.5mm
o Weight 448gr .
Step 7: PROCESSOR Intel LGA 1150 Core I7 4790
characteristics
· Processor Socket 1150 I7-4790 4 core clock speed of 3.6 GHz to 4 GHz Max Turbo Frequency Cache 8MB Instruction Set 64 -bit Maximum Memory Size 32GB Memory Type DDR3 1333
· 1600 GHz Intel HD Graphics 4600
Step 8: Power Supply 725W -PM XPP725 SENTEY
characteristics
· The modular XPP series is designed to provide robustness and reliability with real and continuous power. Power supply 725 W has a single + 12V rail 48A
· Has a 140mm Fan Cooler
· Connectors : 1 Motherboard 20 + 4pines
· 1 CPU + 12V 4 + 4pines
· 6 SATA 5pin
· 4 Molex 4pines
· 1 Floppy 4pines
· 4 PCI- E 6 + 2pines .
Step 9: CASE CC-9011050-WW CARBIDE CORSAIR
characteristics
· Cabinet SPEC- 01 Model Corsair CC- 9011050 -WW 1 USB 3.0 on the front panel 1 USB 2.0 on the front panel Maximum sink 150mm height bays 2 internal 3.5 " bays 2 internal 2.5" integrated 1x120mm Fans Expansion Slots 7 Motherboard Compatible Mini - ITX
· MicroATX
· ATX
Step 10: Finished
  • Epilog Challenge 9
    Epilog Challenge 9
  • Paper Contest 2018
    Paper Contest 2018
2 Comments
i would have gone with a more powerful gpu like the 970 and i also would have went with only 8 gigs since playing games these days arent that tasking. the hyper 212 evo would have been the cpu cooler that i would have chosen but still a solid build with all your parts.
Hello, you 're absolutely right in what you say but you will buy short because these components is that the money for that suited me just unfortunately if not for my part I put wings Thank you for your comment
a huge greeting
