Introduction: Key-man
Keyman made of computerkeys.
You will need: computerkeys, a key ring, some string, all purpose glue, a pair of scissers, little piece of cardboard 2 mm thick. needle
Step 1:
Remove computerkeys from an old keyboard. Cut off protruding triangles with all purpose scissors. You can smoothen te underside of the key with a piece of sandingpaper if neccesary. You will need 16 square keys, 2 long (matching) keys for the body, 2 rectangular keys (matching) for the head. It would be wise to perform steps 1 and 2 for all keys, before going on.
Step 2:
Slot a small piece of cardboard in the center. Glue with all purpuse glue
Step 3:
Make a slipknot in a piece of string
Step 4:
Tie the piece of string round the piece of cardboard
Step 5:
Glue the second half of the head with all purpose glue. This second half should slot tight over the piece of cardboard
Step 6:
Attach a second piece of string just below the head
Step 7:
Find a long key for the body. Repeat steps 1 and 2. Arrange the strings as the photo shows.
Step 8:
Glue the second half of the body on to the first. Make sure the strings remain in the right place
Step 9:
Add square keys to form arms and legs. Follow the first and second step of this instructable for each key. You will need 16 keys.
Step 10:
With a hot needle you can melt two little holes in the top corner of the head and attach the piece of keychain through those holes.
I put a piece of duct tape round the needle to prevent burning my fingers.
Now you are the owner of an original key-man. Enjoy!
