I hate coming home in the snow, rain, and fumbling for keys and balancing grocerys, boxes, ect and trying to pull the door open and hold it while I wiggle the keys out.
so I decided enough was enough.
Materials needed
-one channel (minimum) RF receiver , I used a two channel just incase I needed the other one, but I don't.
I got mine from lightobject.com they have all kinds of cool stuff at great prices
- 12v dc transformer
-bit of wire
A multimeter is handy as well but not necessary.
and I used double sided foam tape to stick it to the wall
As far as I know this will only work on an older style door system thats all analog.
if your front door just has a row of buttons to call each apartment it will probably work.
If you have a newer system that calls your phone it wont.
Remove these ads by
Signing UpStep 1Tone out the wires for the door contacts.
To determine the proper wire combination i first used the multimeter to determine the state of the switch that opens when you pick of the phone. in order to trigger the door control module the switch must be closed momentarily.
Then i used a jumper wire from what i presumed to be the common control wire, and while holding the phone up to my ear i touched the other end of the jumper to the rest of the terminals until i could hear the magnetic contact at the front door buzzing.
In my case , terminals 6,11,10 are the common, and 9 was the door contact. The rest are voice and call wires.
The receiver i used was two channel, however only one is needed.
Because the door contact switch just triggers the controller all we need to do is to pulse the output
momentarily closing the contact which triggers the controller to hold the door magnetic latch open for the set duration of time.
I changed the jumpers on the board to momentary output so that when i press the button on the remote the relay closes just for a second and triggers the controller downstairs
4
comments
Add Comment
iectyx3c
says:
Add Comment
