Step 12Walls walls walls....
iImage Information
Now its just a case of covering the camera with enough walls so that if it is dropped from any angle it will be protected. These walls don't need to be quite as high as the lens wall. I would recommend going for about 2 cm. As this is a camera for kids it also seems like a good idea to use the full range of Sugru colors available. It is best to build up your walls a side at a time (top bottom, front and back) allowing the walls to cure overnight before starting another side. This ensures that you do not damage the walls you have already built while trying to build more. When leaving the walls to cure leave them vertical to help keep them straight. However, before you get wall building there are a few top tips that could really help you out......
