Introduction: Knex 8-shot Semi Automatic RBG (rubber Band Gun)
this is an 8-shot semi auto rbg that i made after looking over some other designs. It uses the 8 cogwheel rubber band gun fireing mechanisim that lots of other ones use.
Step 1: Construct These Parts
You will need these peices: (numbers are approximate)
Rods:
green 15
white 3
blue 12
yellow 4
grey 8
Connectors:
green 17
white 3
blue 2
yellow 10
grey 12
tan hubcaps 6
Rods:
green 15
white 3
blue 12
yellow 4
grey 8
Connectors:
green 17
white 3
blue 2
yellow 10
grey 12
tan hubcaps 6
Step 2: Add the Barrel to the Body
enter longer description for this step
Step 3: Add Cogwheel
Step 4: Add Side Parts to the Body
Step 5: Add These Other Parts
Step 6: Add the Rubber Bands
Step 7: Add Duct Tape
Step 8: It Should Look Like This
Step 9: How to Load and Fire
Put one rubber band on the tip of the barrel and stretch it back onto the white rod on the cogwheel the is straight up. the while holding the cogwheel release the handle part a bit forward and pull the cogwheel back until the next white rod touchs the handle bit and reapeat. To fire it, all you have to do is use the rods on the cogwheel at the bottom of the gun as triggers. Pull it back until it fires and the handle should stop it from firing the whole magazine. However if you put on about 6 or more rubber bands it can sometimes fire 2 or 3 rubber bands at a time. So put a little bit of pressure onto the handle when you fire.
