THIS IS WONDERFUL! I like the lifts and the paths and the elements and the appearance and the....oh, for goodness sake, I like the whole thing! But probably the thing that got me most was the way you got Kariah's wheel lift to do double-duty, as a part of TWO networks. Very smart. ;)
This is the most amazing ball machine I've ever seen! Please, you should really make an instructable on those elements like the skinny grey connector path or especially because I want to know how, and maybe some others the white connector mesh at the bottom.
for the skinny gray path just make the super path with gray connectors.http://www.instructables.com/id/knex-ball-machine-Flashback-elements/step4/super-path/
Best built ball machine for its size. I've seen a couple slightly larger, but this is by far cooler cos it looks strong and neatly built. It doesn't have that cobbled together look, its nice.
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
Thanks!
Pretty much what I said when I saw this.
