Introduction: Knex Door Bomb
K.S.E finished a very import tool for knex agents it's called kdb (knex door bomb) this explosive is very simple and effective when the door hits the block trigger it fires the explosive this weapon is a very good knex spy tool or knex war weapon for inside wars
cons:does not always hit target
pros: small carryable effective
Step 1: Step 1
make the legs using 1 red 1 blue rod and 1 green connecter then make base using 1 snowflake and 4 tan clips which act as grips on carpet
Step 2: Step 2
add the base using 1 snowflake and 4 green rods
Step 3: Step 3
add seven reds on 1 yellow rod
Step 4: Step 4
make the block trigger 1 grey clip 1 white rod and 1 blue rod and 1 red connecter slide it on then put on 2 red connecters
Step 5: Step 5
use the empty space on the barrel to hook it on the top base of the stand
Step 6: Step 6
make the firing pin out of 1 blue rod and 1 grey clip add rubber bands (more you add the harder you have to swing the door open)
Step 7: Step 7
The ammo yellow rod with blue/silver spacers on it or green rods or 3d connecters with orange connecters on it
Step 8: Your Finished
YOUR FINISHED now you can be safe during a war in your room
