Knex door bomb
Picture of knex door bomb
K.S.E finished a very import tool for knex agents it's called kdb (knex door bomb) this explosive is very simple and effective when the door hits the block trigger it fires the explosive this weapon is a very good knex spy tool or knex war weapon for inside wars
cons:does not always hit target
pros: small carryable effective
Step 1: Step 1
Picture of step 1
make the legs using 1 red 1 blue rod and 1 green connecter then make base using 1 snowflake and 4 tan clips which act as grips on carpet
Step 2: Step 2
Picture of step 2
add the base using 1 snowflake and 4 green rods
Step 3: Step 3
Picture of step 3
add seven reds on 1 yellow rod
Step 4: Step 4
Picture of step 4
make the block trigger 1 grey clip 1 white rod and 1 blue rod and 1 red connecter slide it on then put on 2 red connecters
Step 5: Step 5
Picture of step 5
use the empty space on the barrel to hook it on the top base of the stand
Step 6: Step 6
Picture of step 6
make the firing pin out of 1 blue rod and 1 grey clip add rubber bands (more you add the harder you have to swing the door open)
Step 7: Step 7
Picture of step 7
The ammo yellow rod with blue/silver spacers on it or green rods or 3d connecters with orange connecters on it
Step 8: Your finished
Picture of Your finished
YOUR FINISHED now you can be safe during a war in your room
Cool! I'll have to try this.
Just a tip: You'll get more likes and followers if you improve your picture quality. ^^
i set this up behind a door and my brother got hit lol :-)
this is awesome.
nice job.
KnexWarfare2 years ago
Nice job
conaraptor3 years ago
How does it work
it works by when you open the door it hits the block trigger witch in turn releases the ammo
NatNoBrains3 years ago
lol This is soooo good!
mberg3 years ago
How does it work? Do you though it? Our do you attach it to the door?
Foyet3 years ago
I like it it could be used as a gun too.
Check out my knex bombwww.instructables.com/id/How-to-make-a-knex-Bomb-with-tripwire/
Nothing2it4 years ago
I like it. 4*. Hey check out my rail car, just click this link:  www.instructables.com/id/My-VERY-EASY-Railcar/
jack6914 years ago
you can use this as a gun to
couldnt understand the ammo so im making it into a bouncing bettieill just make it shoot a grenade in the air and mabe a trip wire..
K.S.E (author)  meat grinder4 years ago
if u make the trip wire thing show me a pic kk
put some b.b.s down it.
Pizzapie5004 years ago
I liked it sort of, made like 20 mods and now it shoots the ceiling, instead of shooting the enemy
K.S.E (author)  Pizzapie5004 years ago
wat type of ammo are you using because it works for me and from wat i see some more people too
I used a yellow rod with a gray connector attacked to it and some silver spacers on top of that, want some pics of it?
Btw i only did like 5 mods...
i know im smart enough to figure it out
Ok... Just trying to help
Yours and my ammo is bacicly the same all i did was change the tan connector with a gray connector and took off the y connector
why didn't u use the ammo i had listed. or were u trying to make better ammo for it??
If you were spying on someone why would you kill them?
K.S.E (author)  lord voldamort4 years ago
Well incase you were hacking into a computer put this next to the door arm it and when they open the door bam! just to keep you safe during a mission
oh ok
problem with that though is its umm.. kinda made of knex and aint gonna kill them
mr.origami4 years ago
nice i got my older brothers nine times with it until they figured out to use the broom as a precaution
thanx
oh and five stars
K.S.E (author)  mr.origami4 years ago
i'll try to make somthing different you can use on them kk
nice it reminds me of a bouncing betty anti- personnel mine.
Bartboy4 years ago
Or you could put a stopper on the barrel, then put a cap in there.....
or an actual bullet but it might need quite a bit more power
I made one that could (hypothetically, all I had was an empty shell) Shoot 30:30 bullets.
K.S.E (author)  Bartboy4 years ago
For extra power or somthing
K.S.E (author)  K.S.E4 years ago
i mean are you talking about like cap gun cap or what
Bartboy K.S.E4 years ago
A cap gun cap, then it makes a loud bang when they enter. Sort of like an alarm?....
snapper maybe?
arrow shot4 years ago
I suggest punctuation. Things such as . or maybe ,
K.S.E (author)  arrow shot4 years ago
I will take note on that and if you made it please let me know what you think
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
