Knex Pump Action Assualt Rifle
7,972
24
106
Posted
Introduction: Knex Pump Action Assualt Rifle
Knex pump action rifle simple and works well. please comment and rate.
pros
true trigger
very good range with a few rubber bands.
powerful
quick to reload
mag that doesn't have a pusher sticking out the bottom
ten shot mag
can be loaded from the front when the mag is empty without knex fulling out of the mag
cons
rubber bands are hard to put on
takes ages to refill the mag
Step 1: Make the Barrel
this barrel came from the MES V-A1 Sidearm
1. make this
2. make this
3. make these
4. add (3) to (2)
5. add (1) to (4)
Step 2: Make the Magazine
this is my magazine where bullets can be loaded from the front without dropping out the mag. it holds 10 grey / purple connectors.
1. make this
2. make this
3. make this
4. connect to barrel
Step 3: Make the Barrel Cover
making the side covers for the barrel.
1. make these
2. add them to the barrel.
Step 4: Make the Top Section
how to make the top part of the gun, mainly for strength.
1. make this
2. make this
3. join (1) and (2) together
Step 5: Make Other Peices
how to make part of the trigger
1. make these
2. add them to the gun
3. make this
4. add it to the gun
Step 6: Make the Pump Mechanism
this isn't all the pump but its the important bit.
1. make this
2, 3 attach it to the gun
4. make the firing pin
5. add it to the gun
6. end of step
Step 7: Make the Trigger
this is the rest of the trigger
1. make this
2. connect it to the gun
3. add grey rod
Step 8: Make the Handle
1. make this
2. make this
3. join (1) and (2) together.
4. attach to gun
Step 9: Make the Pump
this is the part of the pump that you hold
1. make this
2. attach it to the gun
Step 10: Make the Stock
the stock is not required, if you would prefer not to have it skip this step
1. make this
2. make this
3. connect (1) and (2) together
4. add (3) to the gun
Step 11: Rubber Bands, Loading and Firing
nearly there!!
rubber bands
1, 2. put rubber bands on firing pin
3. put rubber band on pump
4. put rubber band on front part of trigger
loading
5. open mag and put grey / purple connectors in. DO NOT PUT MORE THAN TEN IN AT A TIME.
6. put pusher in, close magazine and put rubber band around pusher.
you are now finished, remember tell me if any bits of my instructions are hard to follow and i will fix them up.
thanks fo building
    • Spotless Contest
      Spotless Contest
    • Pocket-Sized Contest
    • Microcontroller Contest
    106 Comments
    looks good, what are my instructions like to follow?
    can i get a parts list?
    I found it can also shoot white roda
    Cool I built this 1-2 years ago it worked great!
    The one that shows the iron sites is upside down so i can gwt it where u can see it
    I also made it stronger
    I made it and loved it but i dont like the stock so i made the stock from the sk 27 battle rifle on u tube and i added iron sites and a flashlight on the side so its like a cool CIA thing o can give u pics if if u like
