Introduction: Knex Rod Launcher
Picture of Knex Rod Launcher
this was made at my friends house. he improved it a little. it will shoot about 30 ft and is very accurate. this is my first instructable. enjoy!!
p.s. the instructions are very accurate and easy to follow.
Step 1: Materials
Picture of Materials
these are the pieces. not to many.
Step 2: Step 1
Picture of Step 1
pretty easy folks!
Step 3: Step 2
Picture of Step 2
this is tricky.
Step 4: Step 3
Picture of Step 3
sorta hard.
Step 5: Step 4
Picture of Step 4
only put in 1 of the blue rods.
Step 6: Step 5
Picture of Step 5
now add the second set of rods.
Step 7: Step 6
Picture of Step 6
now put on the 2 semi-circle yellows, and flip it upside down.
Step 8: Step 7
Picture of Step 7
add the blue rod and flip back over.
Step 9: Step 8
Picture of Step 8
now add the rubber band around the barrel (greens).
Step 10: Step 9
Picture of Step 9
slip the rubber band in between the 2 blue rods. make sure it is pointing down, and make sure the smooth side of the barrel is pointing towards you.
Step 11: Step 10
Picture of Step 10
put the rubber band in between the first groove from the top and the second.
Step 12: Step 11
Picture of Step 11
slide the gray rod through the greens and the circular whites, pull back untill it almost comes out with the rubber band on the back, and fire at will. (this is not a exuse to fire at your brother "Will".)
note:i am not responsible for any injurys caused by this instructable.
thatgreasymechanicguy (author)2010-10-07
THAT'S WHAT SHE SAID!!!!!!!!!!!!!!!!!!!!
wussap (author)2007-10-16
whats next? knex scissors? knex pencils? knex chopsticks? cmon.......
Bartboy (author)wussap2008-08-15
chopsticks: good
Knexman2020 (author)2008-01-19
meh.... I made a knex rod shooter with only 3 parts. 2 knex ball halfs and a thick stubby rubber band. It could e-z-lee go threw a thick water bottle if the rod was sharpened. But no its on my roof... You can also use a wheel and a shorts stubby rubber band to get the same effect.
flames10391 (author)2007-10-08
lol at least its not a block trigger
oodalumps (author)flames103912007-10-09
Worse, no trigger at all lol.
flames10391 (author)oodalumps2007-10-10
but its still not a block trigger but then again, what could be worse than a block trigger? nothing is worse than a block trigger
oodalumps (author)flames103912007-10-10
This gun is just a bunch of connectors on 2 rods... Worse than a block trigger.
but you don't see many like this on instructables, mostly block trigger/killerk ripoffs/ micro knex guns made of like 3 pieces that shoot a few inches
flames10391 (author)flames103912007-10-10
i just think this whole topic is funny
neoplayer2 (author)flames103912007-11-23
The ONLY thing worse than a block trigger K'nex gun is a K'nex gun that doesn't shoot at all! Sadly, I've made a few nonshooters myself :( (Mostly failed guns, lol)
flames10391 (author)neoplayer22007-11-26
haha
stevoIution (author)2007-10-11
This is almost as awesome as knex furnace tongs. -
Whaleman (author)2007-10-09
wow. Knex guns are devolving! Nooooooooo
Danny (author)2007-10-09
Hahahaha, the amount of negative comments there will be makes me laugh! also learn to use the reply button
ds,ir; (author)2007-10-09
u thought it would be?!? LOL
About This Instructable
1,125views
0favorites
License:
More by ds,ir;:knex rod launcher
Add instructable to:
