Introduction: Knex Rubberband Repeater That Uses Gears
finally, i have made a rubberband repeater that uses GEARS! it has a massive rubber band capacity on the gear. it also has a decent range.
Step 1: Frame
this is the frame. make it correct, or FACE THE CONSEQUENCE of it exploding on you. naw, i kid.
Step 2: Handle
easy, right?
Step 3: Gears\trigger
the main part
Step 4: Assembly
wow, that was fast
Step 5: Supports
helps support the rubberbands. kinda bad pics sorry
Step 6: Ah, the Trigger
the trigger goes on the 45 degree angle on the snowflake. make sure that the green rod in the back of the trigger is one space apart and the one in front is 2 spaces apart. attach the rubber bands on the trigger anywhere you please, i dont care.
Step 7: Loading and Firing
load the rubberbands on the 2 yellow connectors and put it anywhere on the gear. press the trigger and it should click and move up one space. keep pressing the trigger until it fires.
