Introduction: Knex Sidearm
i made a big rifle but i also wanted an effecient small pistol like weapon. here it is!
PROS-
-light
-easy to make
-holds 11 rounds
-adjustable front sight
-shoots 50 feet with good bands
CONS-
-rediculously unaccurate
-your hand will sometimes interfier the ram while firing
-ram can sometimes be hard to pull back because it will catch on the ammo
RATING- out of 10
mobility- ========== (10)
range- ======= (6)
accuracy- ==== (4)
ammo capacity- ======= (7)
suggested retail price- 10,000 dolphins
Step 1: Handle, Ram and Trigger
sorry, image notes wont save,
pic 1- 10 blue connectors attached with 2 yellow rods
pic 2- make (the black piece on top is a Y connector
pic 3- make
pic 4- attach
pic 5-the top is the mag pusher, the middle is the ram, the bottom is how to make the ram and you can chose between the black or orange piece
Step 2: Mag
the bottom orange connectors can be single slot connectors i was just too lazy to find any :P
pic 1- same pannels for both layers
pic 2- side
Step 3: Barrel
pic 1- top- cut orange connectors :( , bottom- sight
pic 2- back of the barrel
pic 3- middle of the barrel (the clips on the very right must face inwards so it can guide the trigger)
pic 4- end of the barrel
pic 5- attach
Step 4: Assembly
pic 1- handle goes here
pic 2- trigger goes here, the y connector attaches to the black snowflake
pic 3- place a 2 slot connecter on both sides like so and attach with a blue rod
pic 4- attach the mag like so... (you may have to remove the top semi circle connector and slide through the top, next to the bullet guide
pic 5- put the ram through the back and add the back sight (please turn the sight around...its only turned in this pic so u know what connector it is)
pic 6- mag pusher goes in like so
pic 7- fires white rods
Step 5: Done!
attach a rubber band so it pulls the mag pusher up, and a rubber band to pull the trigger up when the gun is loaded. then just add rubber bands to the ram so it fires!
