Knex Assault Rifle
1,404
7
17
Published
Introduction: Knex Assault Rifle
this is a simple but very powerful knex gun. it takes about an hour or 2 to build. please comment i want to know what you think. This is my first gun. i also give credit to the guy that created the handle it is not mine and i dont take credit for the handle. I also dont take credit for the slide. this also isint my design.
WARNING!!!!!!!!! THIS GUN IS POWERFUL AND NOT A TOY. DONT AIM AND OR SHOOT AT ANYONE THAT IS NOT READY OR DOES NOT WANT TO BE SHOT AT. I AM NOT RESPONSABLE FOR ANY INJURRYS THAT YOU INFLICT ON YOUR SELF OR OTHERS. YOU HAVE BEEN WARNED. now that the warning is out of the way lets get building! here is a list of pros and cons for the gun. HAVE FUN!!!
PROS:
1. very strong body so dont be affraid to add lots of rubberbands (maximum of 12. 6 on each side of fireing pin.)
2. true trigger
3. removable clip
4. very reliable and rarly jams.
5. easy to unjam
6. large clip (holds 20 rods)
7. accurate
8. shoots up to about 60ft+
9. NO MODED PEICES!!!!!
10. small and compact.
11. only need normal side rubber bands!!!!!!!
CONS.
1. peaces will break after about 1000 shots. just replace them.
2. Slow reload time.
3. once you put the mag in it might be hard to pull the fireing pin back so just grab the mag and wiggle it around for a secound then pull firing pun back. if it doesn't worke after that your rubber band on the mag is to tight so get a looser one.
Step 1: Clip
1. finish product!
2. build this.
3. add these.
4. collect 8 white rods and build these
5. connect these 2 sides by conection the side of the clip to the sides with 4 white rods
6. add the other side of the clip and connect it with 4 white rods.
Step 2: Top Rail
1. FINNISHED PRODUCT!!!
2. collect and build these parts. (there are 10 orange conectors and 18 grey connectors)
3. build this there should be one more orange connector left.
4. add 9 grey conectrors onto both sides inbetween the orange connectors.
5. build this
6. add onto main part
7. add these onto the other side of the main part
Step 3: Grip
1. finished product!
2. gather these peices
3. build this.
Step 4: Firing Pin
1. finished product
2. build these
3. assembal peices
Step 5: Wallsof the Gun
1. colect and build these parts
2. assembal
Step 6: Rear Barrel
1. colect and build these peices
2. build this
3. and on a secound layer of snowflade peices
4. add these
5. add a 3rd layer of snowflake peices
6. add a 4th layer of snowflake peices
Step 7: Front Barrel
1. collect and build these peices
2. build this
3. and a 2nd layer of snowflakes and add these peices. (srry i forgot a pic)
4. add a 3rd layer of snowflakes.
5. add a 4th layer of snowflakes.
Step 8: Stock of Rifle
1. collect and build these peices (these 4 peices that are the same will be called layers.
2. build this
3. add a layer
4. add these peices.
5. add a layer
6. add a layer
Step 9: Bottom Rail
1. collect these peices. (there are 30 grey spacers)
2. build this
3. add on
4. add on
5. add on
6. add on
Step 10: Trigger Guard
2. build this
3. add this peice
4. add this
5. add this peice
6. add this peice. ( sorry for pic quallity.)
Step 11: Handle
2. build these (Again sorry for the pic quallity)
3. add the peices you just built to one side of the handle
4. add other side of handle
5. add this peice
6. same as step 5 just on the other side.
Step 12: Trigger
1. collect these parts
2. build this
3. add this
4. add this
Step 13: Chamber
2. build this
3. build this
4. attach to main part
5. build this. ( if you dont have this many blue clips then you can use 5 clips. i ran out so i had to settle for blue clips. blue clips also work better.)
6. add to the main part
7. put black y connectors inbetween the brown clips.
8. add orange connectors to the y connectors
9. add thees rods and blue spacers.
Step 14: Part That Firing Pin Slides On.
1. build this.
Step 15: Assembling All the Parts!!!!
1. attach the front barrel to the chamber.
2. attach the rear barrel to the chamber
3. attach the top rail to the front and rear barrel.
4. attach the handle to the rear barrel
5. attach the trigger guard to the rear barrel and the handle
6. attach the trigger to the handel.
7. attach the walls of the gun to the front barrel and the trigger guard
8. attach the grip to the front barrel and the walls of the gun.
9. attach the part that the firing pin slides on to the rear barrel
10. attach the bottom rail to the handle
11. slide the firing pin on to the two rods
12. attach the butt of the rifle to the rods and the bottom rail.
Step 16: Rubber Bands.
for the fireing pin put 6 bands on each side of the blur rod.
    • Casting Contest
      Casting Contest
    • Woodworking Contest
      Woodworking Contest
    17 Comments
    nice man 10out a/5
    hey jamalam srry that was my little bro saying that stuff srry. you need to keep up the good work your guns are great. my new gun is here. alright everyone it is 7 pounds and 4 ft long. i call it the xhm. the hm stands for haevy maching gun and the x just looks cool. pics will be out soon.
    Lol so you say this beats me, do you? And it only shoots 50 feet because you used 12 rubberbands. Get real dude!
    hey guys I no its been a while but I will have a new gun out by the end of July I've just been tweaking it so it shoots longer and harder. this one also has guaranteed better looks!!!!!
    hey srry it took so long. it is the size of a large grey rod but stronger. a normal large grey rod will do but it has a chance of bending or snapping if you put on the suggested amount of rubber bands.
    sorry i forgot about the slide ill fix that.
    i don't think you created the slide
    well mepain mentioned the slide in his ibles which is posted before you posted yours , which means someone made it already
    that was added after i posted by one of the collaborators. i looked around to make sure it wasn't done before
    looks naked:)
    pretty good, 4*
