Knex Gun/bow Trap =)
Introduction: Knex Gun/bow Trap =)
what you do you shoot the target then the cage drops down onto your thing that you want traped
Step 1: Parts List
connecters/full moon,orange double mini black thing
rods/,8 red,1 bendy (big)
Step 2: The Cage
join 8 red connecters to the white connecter
Step 3: Make the Hook
just add the pieces to the rod
Step 4: Add the Hook
join everything together then set it up
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
    ive put the picture on the main page
    Most of your red rods are bent.
    ive made better traps. for example, i made 2 teethed plates, hinged them together, put a rubber band around them, spread them apart, then put a small, loose rod inbetween them. When the rod was moved, the trap would snap shut and trap or kill the animal, depending on if the teeth caught it. I also made a pitfall which was a plate and a rod and...yeah, simple. But this, this doesnt look good. If you want to make a good cage, there needs to be a trigger that can be set off by the animal, and it needs to have some type of support. Like maybe a tripod taht holds the cage above, and then the cage is on some sort of sliding mechanism.
    i modded this bear trap so that all u do is touch it and it snaps together <br/><a href=""></a><br/>
    thanks i hope u enjoy it m8
    its my first cut me some slack!!!!
    wait....hold on....this is a trap!? I'm not being mean but what does it do? i tried making it and doing the rest but traps are not your thing probably.
    I don't understand how it traps it..... It could fall on it, but not trap...
    it falls down then it puts the red cage around the item you trapped
