K'nex/bb Shooter
Introduction: K'nex/bb Shooter
Dont know how far it shoots, but its not bad.
Step 1: Step One.
just make this. easy-peasy.
note: these are 8 dark grey one-slot connectors.
Step 2: Step Two.
also easy.. just make it:)
Step 3: Step Three
Assemble these two.
Step 4: Step Four.
make these.
Step 5: Step Five
Pic 1: put it on the back.
Pic 2: assemble the blue sticks with the red connectors on it.
Step 6: Step Six.
put one grey 1 slot connector behind the back stand.
Step 7: Step Seven.
Bend the rods so they're only with the back on the ground.
Note: the orange thing at the top isnt made yet:D
Step 8: Step Eight. Almost Done!
Make the firing pin.
Step 9: Step Nine. Finished!
get the firing pin in, and put a rubberband on it. you have to put the rubberband under the front hole. pull the pin back and push it a little bit down, so it leans on the firing pin.
Step 10: Step Ten. How to Shoot?
not hard. just push the blue rods so the pin is'nt blocked by the top of a connector. Load the ammo in the front. (bb/small green rod)
Don't forget to comment! I hope you like my gun!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    u could do the same thing only with a red rod so more bbs and it could be a shotgun
     i added a longeer barrel and added grips instead of a tri-pod i also added a bolt blocker using a orange connector paice
    when as it been done
    im making this ill post pics when im done ps very simple but mine hassent got the blue legs on
    GREAT , i had loads of k-nex but i lost it when i find the correct peices i iz definatly making this
    some pictures are a little bit dark, I advice you take the pictures in a well lit room, or when thesun is up. but it is a nice little gun.
    but its not bad.
