Introduction: Laser Printer Carrying Case Home Made
ever wanted to carry your laser printer or anything that is fragile on a plane,car,or moving company and not worry about.
I fitted this luggage bag with some foam and it does the trick.'''''''''
Step 1: Things You'll Need:
*foam (meant for single bed)
*utility knife
*long enough ruler or like I did a scrap piece of 4x4
*felt pen
*piece of hard cardboard(I use the box from the printer)
*utility knife
- hot glue gun
- plenty of glue sticks
*felt pen
Step 2: Gut Your Case
only need to cut the bottom part, depends on the case you are using.
Step 3: Measure and Cut Your Foam
add a bit of support by adding some cardboard to the back of the case glue it down of course.
Step 4: Trim and Fill
now measure the lid and around the inside and start using that glue gun you had for a long time wanted to use it.
and yes , measure 'cause I try not measuring and I find out foam moves a lot ,ah yes the felt pen that's what I use it for.
