3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
launch it! wood sling shot
true wooden sling shot max range 200 feet, 71 miles per hour! just uses 6 rubber bands wood frame string re-enforced.
Now u could just pick up a Y shaped stick that u found and use it but it wont be as strong and its more fun to make your own frame.
this instructable is easy to do it will take more than 1 day to build because its constructed with 5 min epoxy so you have to give it time to dry i finished it in 2 days working off and on.
Always use safety glasses when shooting a previous sling design had a habit of firing backwards on occasion, thank god i didnt have contacts back then or id be blind in one eye.
Step 1Get your materials
get your materials
  • last photo ←
you will need:
3 5 inch X 3/8ths X 3/8ths balsa wood (aprox) 2 inch X 3/8ths X 3/8ths balsa wood (aprox) 5 min epoxy (craft/hobby store)4-8 rubber bands depending on size thickness and strechyness stirring sticks for epoxycup for mixing epoxy clamp/vice scissorswire cuter stringcloth  for sling (see below)(i just used [http://www.acehardware.com/sm-scott-and-reg-rags-in-a-box-75260--pi-1275301.html Rags IN a Box]) staplerabout a cup of flower
(i just used Rags IN a Box) as a substitute for cloth
Build in well ventilated area like out side or garage
always use safety glasses when firing
never shoot a living person tree or animal
(unless your using in paint ball which i dont recommend)
im not responsible for any thing you do if you damage something your self or some one not my fault
28 comments
Aug 26, 2007. 8:43 PMliny says:
rubber bands are not strong enough to be compared to real slingshots. My father made slings using old tire rubber as rubber bands.
Nov 3, 2011. 5:19 AMPasky95 says:
Yes tire interiors are far better than rubber bands. However silicone/rubber tubes propel your projectiles faster than interior rubber. :-)
Nov 3, 2011. 5:21 AMPasky95 says:
I think this depends on the projectile you use. If you intend to use your slingshot in hunting and use a denser projectile (ball bearing or marble) then a stronger rubber might be needed. :-)
Jun 29, 2008. 4:11 AMPhoghat says:
I would think balsa is kind of flimsy. When I was a kid I used to make these out of 3/4 ply and sometimes they'd still break.
Mar 16, 2009. 8:12 PMstAzer says:
I would say that it's not stronger than a forked branch, and your design is off. Also, you can buy latex rubber tubing that's much, much stronger than rubber bands at hard-ware stores. And you can't beat a leather shoe tongue for a pouch.
Nov 3, 2011. 5:16 AMPasky95 says:
I agree! Rubber/silicone tubes shoot your projectiles much faster than rubber bands or interior rubber. Leather is also much more durable and can last for years.
Jul 22, 2008. 7:49 PMskimboarder33 says:
great instructable but for most people you actually hold your sling in indominent hand and pull back with dominent? i think pleese correct me if im wrong:}
[=[_]=]
[+[_]::]
Nov 3, 2011. 5:12 AMPasky95 says:
I think this varies from person to person. Many people shoot their slingshots the way they shoot a bow i.e. pulling the string with their dominant hand. I use my dominant (right) hand to hold the grip and stretch the slingshot at the same time. My left hand holds the sling next to my cheek as I push the grip forward and shoot. :-)
Oct 2, 2009. 4:40 PMmikaelthemycologist says:
I shoot a bow with my dominant (right) hand on the string and my indominant hand holding the bow. With a slingshot though, I find that my indominant (nondominant?) hand pulling, and my dominant hand on the slingshot, gives me more strength and accuracy.
Jul 11, 2009. 12:20 PMCapnTac says:
Yeah, that's what I do. But it might just be because of years of archery...
Jan 15, 2011. 8:38 PMbloodyblahblah says:
sorry i need 2 put you down a little:
That was *beep*
Aug 24, 2007. 11:09 AMtomonto says:
how do you have a range of 30 to 200 feet?
Jan 6, 2010. 5:58 PM35Timmy says:
you can shoot  around 35 ft by getting strong enough elastics shoot harder
 and father and get used to a higher raneg even do target peratice until you
reach far enough and try pulling back harder
hope you use it in peace
Mar 28, 2009. 10:32 PMFlash Gordon says:
Awesome rated 5.0
Dec 20, 2008. 3:52 PM15zhangfra says:
i made something somewat like this the other day with paper and and duct tape, cardboard reinforced
Jul 8, 2008. 2:31 AMAnton1995 says:
Check out my slingshots HERE
Nov 3, 2007. 9:43 AMX_D_3_M_1 says:
typo in step 5. string or sling?
Sep 22, 2007. 11:27 AMKings_Fool says:
Whats a "clap"? Did you mean "clamp" :P
Aug 25, 2007. 8:32 PMellomate56 says:
Mailman or garbage truck in the background? haha
Aug 26, 2007. 2:03 PMellomate56 says:
thought so
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:i make shooting things
