Amazing 3 dimensional LED display.
64 LEDs makes up this 4 by 4 by 4 cube, controlled by an Atmel Atmega16 microcontroller.
Each LED can be addressed individually in software, enabling it to display amazing 3d animations!
8x8x8 LED cube now available, by popular demand:
Step 1: What you need
First of all, you need quite a bit of time to solder together 64 leds ;)
Knowledge list:
  • Basic electronics and soldering skills
  • Know how to program an AVR microcontroller - I will not cover that in this instructable.
Component list:
  • Protoboard. The type with copper circles.
  • Atmel AVR Atmega16 microcontroller
  • Programmer to program the Atmega16
  • 64 Leds
  • 2 status leds. I used red and green. (optional)
  • Max232 rs-232 chip, or equivalent.
  • 16 resistors for leds. (100-400ohms) will get back to this.
  • 2x resistor 470 ohm. for status leds
  • 1x resistor 10k
  • 4x resistor 2.2k
  • 4x NPN transistor BC338 (or other transistor capable of switching 250-ish mA)
  • 1x 10uF capacitor
  • 1x 1000uF capacitor
  • 6x 0.1uF ceramic capacitor
  • 2x 22pF ceramic capacitor
  • 1x crystal 14.7456 MHz
  • 2x tactile button
  • optional pwr switch
  • connector for 12v power
  • optional connector for 5v power
anyone experienced to offer some insight? i ve built many using arduino but i ordered one online a kit one and it came wirh no instruction. it runs off a driver and has sound sensor anyone know how to build it
I have been trying to find a tutorial for a bi-colored led cube. Do you have any idea where I could get some help with one in a 4x4x4? Thank you, Thom Mulford
<p>Right, so i placed RTC to show time, made enclosure from oak, finished with linseed oil, and placed mirror-plating as extra touch to create infinity-mirror effect, only in milder effect, it can be viewed in every direction</p>
<p>forgot to add, took hints/information from your bigger cube like that soldering jig, thanks!</p>
<p>Great project man! <br>Can u send me the code? &quot;HEX&quot;</p><p>Thanks!</p><p>giovanni_25_8@hotmail.com</p>
<p>Hai haii..</p><div>I made led cube 3x3x3<br> Obstacles that arise is when<br> - 3x3 layer 1 __ Is correct (all live)<br>- 3x3 layer 2 __ Is correct (all live) <br>- 3x3 layer 3 __ Is correct (all live)<br><br> Why when I combine layer1, layer2, and layer3 (Many LED DEAD).<br><p>I want to know why many LED die ???</p><p>Thank you very much</p><br><br></div>
<p>check out my 4x4x4 LED Cube</p><p><a href="http://ps-microcontrollerprojects.blogspot.in/2015/09/4x4x4-3d-led-cube-using-avr-atmega16.html" rel="nofollow">http://ps-microcontrollerprojects.blogspot.in/2015/09/4x4x4-3d-led-cube-using-avr-atmega16.html</a></p>
<p>tell me how to generate code for 4*4*4 led cube.,.,</p><p> plz send me link for generationg code for AVR.</p>
<p>can i use a bc548 instead of using bc 338 transistor</p>
<p>Hello, I'm a free user and i wanna make this project. It is showing 11steps, are they complete or should i turn to a paid user?<br>Please tell</p>
<p>There are only 11 steps, free uses can see all the steps and comments, but can not download the project as a pdf, support the site and other things.</p>
<p>I am facing problem in compiling code . Which compiler or converter should be used to convert the above .c files to .hex files</p>
<p>Is Willar programmer fine for Programming Atmega16??</p>
<p>I put the .hex file on the desktop. I got in command prompt this message:</p><p>error opening 4x4x4_ledcube.hex: no such file or directory</p><p>Whats the problem?</p>
<p>I would really like to start this project; it looks so cool! Could I build the 8x8x8 with the Arduino Uno instead? It only has three ports so would it even be possible or would I only be able to build the 4x4x4 cube with the Arduino Uno? If I have to do the 4x4x4 cube, the wiring would probably be different and the code would remain the same though right?</p>
<p>Ungrounded layers sometimes light dimly:</p><p>I built a prototype of a 4x4x4 LED cube on a protoboard following the anode column/cathode layer approach with a set of current limiting resistors between the columns and an arduino controller and close the plane circuits with a set of 4 transistors in the software with an intent to only have a single plane on at a time. As I&rsquo;ve been testing my cube, I found that the fewer the leds that I have lit, the more pronounced an unpleasant effect is where other leds in an activated column (but unactivated plane) light dimly. I&rsquo;m really unsure why these leds would light up. The effect seems more pronounced with fewer leds being lit at a single time and totally disappears when all 16 leds in a plane are lit. Surprisingly, if I remove all grounding that closes a circuit, the activated column still lights with a diffuse lighting across the leds in the column. I&rsquo;ve <a href="https://www.youtube.com/watch?v=8O-Z7RAQRX8" rel="nofollow">linked</a> a video that shows the effect in the hopes that someone can help me understand what&rsquo;s wrong. net/net, I copied this design but hooked it up to an arduino</p>
<p> <br> <br>I love this blog!! <br> The flash up the top is awesome!!</p><p><a href="http://www.monacopropertylistings.com" rel="nofollow">appartamenti a monaco</a></p>
<p>I have problem with the usbtinyisp. who can help me?</p>
<p>You need to install windows driver for your 'usbtinyisp' first.</p>
<p>I installed the driver and the usbtiny communicated with the chip. But when I try to setting the fuse, the programm tell me something like &quot;change 0 with ... (y/n)&quot;. I write &quot;n&quot; and from this moment the usbtinyisp can't communicated (connection failed, rc=-1)</p>
<p>i need to know how can i programme a cube led 4*4*4 without arduino !!!! plzzzzz</p>
<p>can you email me the program with &quot;mikropascal pro&quot; ? khouloudkalil@gmail.com</p>
<p>I built my ledcube thanks to your awesome tutorial, but saw this &quot;To compile the program, open a command prompt, enter the directory with the source code and type &quot;make&quot; on the command line. You should now have a file named main.hex in the source directory&quot; I tried that with the source files and I get all kinds of errors. C:\WinAVR-20100110\xledcube&gt;make</p><p> 0 [main] sh 2156 sync_with_child: child 1572(0x14C) died before initializa</p><p>tion with status code 0xC0000142</p><p> 670 [main] sh 2156 sync_with_child: *** child state waiting for longjmp</p><p>/usr/bin/sh: fork: Resource temporarily unavailable</p><p>-------- begin --------</p><p>avr-gcc (WinAVR 20100110) 4.3.3</p><p>Copyright (C) 2008 Free Software Foundation, Inc.</p><p>This is free software; see the source for copying conditions. There is NO</p><p>warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.</p><p>Compiling: main.c</p><p>avr-gcc -c -mmcu=atmega16 -I. -gdwarf-2 -DF_CPU=14745600UL -Os -funsigned-char</p><p>-funsigned-bitfields -fpack-struct -fshort-enums -Wall -Wstrict-prototypes -Wa,-</p><p>adhlns=main.lst -std=gnu99 -MD -MP -MF .dep/main.o.d main.c -o main.o</p><p>In file included from main.c:74:</p><p>draw.c: In function 'setplane':</p><p>draw.c:170: warning: comparison between pointer and integer</p><p>draw.c:170: warning: comparison with string literal results in unspecified behav</p><p>ior</p><p>..... long list down. What is the problem ? I want to try this to remove some of the effects. I already uploaded the hex file but I want fewer effects.</p>
<p>hey. can u email me the program? hediana11@yahoo.com</p>
<p>Hi there, I want to make my LED Cube on STM32F4 Discovery board. It has Current Limit 150 mA and I have only 270 ohm resistors, which give </p><p>3V Ouput</p><p>11 mA per LED</p><p>177 mA when all 16 LEDs are ON. Will it damage my board?</p><p>Here is documentation link, p 77</p><p><a href="http://www.st.com/web/en/resource/technical/document/datasheet/DM00037051.pdf" rel="nofollow">http://www.st.com/web/en/resource/technical/docume...</a></p><p>P.S. Thanks for great instructable!</p>
<p>I made the cube with this board.</p><p>It won't damage the board. You will have only 150/16~9 mA per LED instead of 11 mA.</p><p>The side-effect is that one LED in layer will glow brighter then 16 in the same time.</p><p>P.S. sorry for my english.</p>
<p>i want to make a 5*5*5 led cube.what changes should i consider??</p>
<p>Hello ! Thank you for this awesome instructable.<br>I made a mistake while programming the microcontroller. <br>I ran &quot;avrdude -c usbtiny -p m16 -U lfuse:w:0xc9:m&quot; instead of &quot;avrdude -c usbtiny -p m16 - U hfuse:w:0xc9:m&quot; (the difference is &quot;lfuse&quot; instead of &quot;hfuse&quot;).<br>What's the command to reset the microcontroller ? <br>Thank you for your help.</p>
<p>Great Instructable!!!</p>
<p>Wahoo! It's finally complete! One of my inner bottom LEDs just died on me though :( That will be fun to switch out.</p><p>This instructable was great!</p>
<p>Time to move up to an 8X8X8 for your next project - and then on to the 8X8X8 RGB....fortunately got you I have instructables on both!</p>
<p>ok then how i can set the fuse bits .... plz tell me.....</p><p>i am using top2008(a universal programmer) burner to program the atmega......</p><p>thanx for the reply</p>
<p>Hello. Thank you for this great detailed instructable, it helped me alot. But i have a question, if all leds will be turned on, wouldn't they all consume (4*4*4)*0.012A=0.768A? And what will be with microcontoller, when its allow max 200mA at once?</p>
<p>Firstly - there are current limiters on the LEDs.</p><p>Second, only one layer is on at a time, max 16 LEDs</p><p>Third - LEDs are modulated - not ON with DC .</p><p>End result - very VERY little current draw.</p>
<p>From what I know the LEDs are not turn on all at once but one by one in a very fast rate nearly 200 frames per second, just giving the illusion of them turned all at once.</p>
<p>Thanks for reply. Thats right what i was thinking :)</p>
<p>i program the with given hex file but speed is very slow how can i increase the speed.</p>
<p>I am guessing you forgot to set the fuse bits to use the external crystal, so the ATmega is running on the internal 1 or 4MHz clock rather than the external 16MHz.</p>
<p>Or in this case, the external 14.7456MHz.</p>
<p>how can i increase the speed please tell me</p>
<p>Hello. Tell me, what transistors attach layers.</p>
<p>i am new to programming can someone please tell me how to start or insert codes in this thing. Thank you..</p>
<p>I LIKE THIS</p>
<p>i see people can't seem to read.... it's not hard. 'save as' re-name </p><p>F6JRI6AFJ1I6CP0.tmp</p><p>to main.hex. upload to atmega16 chip and you are done!</p>
How to increase the flashing speed of led.... ?
i have a question&nbsp; how do i use the zip file? the hex i can use it from windows to send it to avr but the zip i didn't know how to use..! can someone tell me if it s important o not?<br />
<p>the zip file contains the original naked coding files which you can edit if you want to, but if you dont know what you are doing... dont touch it.</p><p>if you uploaded the .hex file... you've completed the programming of the atmega chip and theres nothing more you need to do</p>
How do you connect an avr to your pc for the code to load on it? And yes I&nbsp;do have linux<br />
About This Instructable
1,454 favorites
Bio: I like microcontrollers and LEDs :D
More by chr: Reverse Engineering: RGB LED Bulb with IR remote Reverse engineering: USB controlled home automation hack LED Cube 8x8x8
Add instructable to:
