Led Glowee
Published
Introduction: Led Glowee
items needed is:-
a cr2025 or similar button cell
and an led
Step 1: How to Connect?
well in any case its simple and very easy step...just connect the longer terminal to positive side of cell and negative terminal to other side....simple
Step 2: Thats IT.....
well all u need is some patience and some adjustment in attaching led with cell and eventually u will make it.....yepee...
Step 3: What Else Can U Do....
well u can use this as a handy torch or u can make bulb glowee....that will be in my other tutorial...thanks for watching.
    • Water Contest
      Water Contest
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    3 Discussions
    I guess there's no rule that says you can't redo an old Instructable.
    Sometimes the next person provides a slightly different way of doing the
    same thing."
    And sometimes it is not so easy to find out before!
    But I also guess most people do not even try!
    I guess there's no rule that says you can't redo an old Instructable. Sometimes the next person provides a slightly different way of doing the same thing. Having said that, it is always nice to see when someone has done their homework into the history of the project. I've seen the same paper airplane designs posted over and over (and over) over the years.
    No offense but this is not new. They were created by Graffiti labs and are the same thing as led throwies. The only difference is yours does not have a magnet. I don't know if you knew this but this has been done a couple of dozen times over. Again not trying to be mean, even though what I said is condescending in it's tone.
