Introduction: Led Strip Lamp
Picture of Led Strip Lamp
Things You Need to make your instructables
Old lamp
pvc tube
12v dc
1m led strip
Step 1: Assembly the Lamp
Picture of Assembly the Lamp
I used onely the cfl screwbase and conect it with 12v dc adapter
Conect 220v or 110v side of adapter on cfl and the 12v + - with led strip
Step 2: Add the Led
Picture of Add the Led
Conect the 12v + - with led strip
Step 3: Finish the Job
Picture of Finish the Job
The 150 lux lamp
nasher_87 (author)2016-09-07
Very good job, I never thought anything like it.
How many LEDs per meter is 30 or 60 / m? It seems 30 and 3825 smd.
What recomendas power supply led me to strip smd 5050 60 leds per meter?
Thank you
vacomcom (author)nasher_872016-09-18
12v 1200mah power supply per meter
nasher_87 (author)vacomcom2016-09-18
Thank you very very much
k24tea (author)2014-11-23
Nice idea and pix, but not enough info. Please include detailed step-by-step directions and the specific parts you used to make this.
sailorondatea (author)k24tea2015-02-06
Just put 12V adapter inside CFL case, from it's size I guess max 1A rated but even 500mah would be enough, pretty much common type. LED strips work on 12V directly since they have built-in resistors. +12-----|>---|>---|>---/\/\/\/\/\------0 if you dont cut, each pack of 3 is connected in parallel with others. So if you wrap 60LEDs it makes 20 packs in parallel. Assuming each draw 20mah 20*0.02A=400mah. See?
rimar2000 (author)2014-11-13
cerrituss (author)rimar20002014-11-13
Electrospark (author)cerrituss2014-11-17
" "?"?? " ????? XD
tominjose (author)Electrospark2014-11-22
denewf (author)2014-11-16
Where do you determine 110V or 220V.
newbie
vacomcom (author)denewf2014-11-17
if you live in different voltage zone (Europe use 220v, America use 110v)
terrible tinkerer (author)2014-11-16
Very nice! The 12v circuit board from the wall wart - any particular amperage? I have a few ranging from 200mA to 1000mA.
I use 800ma or 1000ma .
ballardbk (author)2014-11-13
These are great pictures, but some actual written instructions would help this become a great instructable.
About This Instructable
6,674views
53favorites
License:
More by vacomcom:Footprint Stone EngravingStone Engraving Heartsled strip lamp
Add instructable to:
