3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
led + arduino "running light" (very simple, good for beginners)
led + arduino \"running light\" (very simple, good for beginners)
hello
so this is my first arduino project. it is very very simple and it is good for beginners
basicly its just leds hooked up in a row to make a running light
Step 1Materials
Materials
-8 x Led (I used 3V Leds because i didnt have 5v ones)
-Arduino
-Breadboard
-Jumper Wires
Optional:
-Prototyping Shield
12 comments
Apr 15, 2012. 4:55 PMmasprotech says:
I have been looking for this for a while now...... All others have been over done this is simple and to the point Thanks very much
Jun 28, 2011. 10:52 AMibecake says:
Just did this as my first arduino project excellent start big return for small input.
Great Instructible.
Feb 10, 2011. 5:34 PMsnotty says:
Nice easy to understand code. This is great for beginners.
Here's a sneaky trick for your resistor: put one resistor in series with your ground wire on the negative side of your LEDs. This is not going to be good if you reprogram to have all of your LEDs on at once but it's better than nothing. Ideally you'd have one resistor per LED but it's better to have some safety than none.
I blew the USB chip on my Arduino once doing something like this. It was bad news.
Again, nice simple project :)
Feb 8, 2011. 3:23 PMjman 31 says:
Maybe I am missing something, but shouldn't you have a resistor in series with each of those led's.
Feb 8, 2011. 4:10 PMfrank26080115 says:
You should always limit current through the LEDs. To prevent damage to the LEDs and prevent damage to your microcontroller pins.
Feb 9, 2011. 4:49 AMjman 31 says:
Yep frank26080115 is correct. First you will drastically reduce the life of your LED which isn't that big a deal because they are cheap, but the microcontroller would be the big worry. Diodes don't limit current so there is basically just a short to ground. You may get away with it for a while if you are just flashing the LED's, but it will catch up to you eventually. basically any resistor from 470 ohms to 1K should work.
Feb 9, 2011. 8:26 AMjman 31 says:
Definitely keep on experimenting! You will learn as you go and those that have constructive input usually are willing to teach. I learned just about everything I know about electronics through trial and error and input from knowledgeable folks on the internet! :)
Feb 8, 2011. 1:53 PMBongmaster says:
neat :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:quaddel
