3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
light box
light box
I needed a light box for tracing airfoils from kites (among other things).
I had some old fluorescent lights and of all things a recessed skylight box housing thing that looked perfect for the job.
Step 1Find a fluorescent bulb
and associated ballast, rip the things apart to get the pieces you need.
9 comments
Oct 22, 2009. 10:03 AMsunshinecook says:
Thanks for the instructions! I also found this guideline for a smaller one using fluorescents in standard fittings as suggested. I think the advantage there is very even light (good for detailed tracing) without much heat.
http://www.eleventyhandmadedesign.com/2009/10/homemade-light-box-with-fluorescent.html
Feb 4, 2010. 8:45 AMgurelli says:
hello sunshinecook, your link to this great tutorial can use a little update:
http://www.eleventytheblog.com/2009/10/homemade-light-box-with-fluorescent.html
Oct 3, 2009. 9:34 AMweasel999 says:
I made similar alot simler by using an old scaner top and a flashlight
May 21, 2009. 8:47 AMneedexercise3 says:
Great, simple project! In the photo it looks like the lighting is nice and even. For the second fluorescent, maybe a higher wattage bulb? Or another of the original fluorescent fixture? Or bluelion's idea, with a reflector behind. For the second bulb, I've heard that straight-tube fluorescent fixtures have metal reflectors because they need a conductive surface nearby to help them start up. Try setting a white metal reflector behind the bulb. The reflector would help, anyway.
May 20, 2009. 3:05 AMgrimgroper says:
just thought of this... but if you want a smaller one say 17" you could pull out the back light and diffuser from an old lcd monitor, get rid of the graphics driver and you have a nice thin ( approx 1cm thick) desktop light box if you want to get thiner you could try a laptop but powering might get slightly more complex)
Apr 14, 2006. 7:33 PMmahbooty says:
where do you get the translucent plastic?
May 19, 2006. 1:05 PMSilvester10528 says:
Check at Home Depot or Lowes in the door department; they should have something for screen doors. If not there, check in the lighting department near the large industrial ceiling fixtures.
Dec 20, 2007. 4:00 PMringworld says:
Yes but it would get mighty warm. Using 1 or perhaps even two CFL may work well. Just place some tin foil to help bolster full coverage. My biggest concern is the burning PS foam gives an acrid smell and very toxic. Burning Aluminum quite different and not as toxic.
Apr 9, 2006. 1:14 PMbluelion says:
how about replacing the light with those fluorescent lightbulbs that fit in a standard light fitting.... you could put 6 in there...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
110
Author:saul
