for the first one you will need:
-R1(LDR) 10K
-R2 (1.2K) colour code: brown, red, red.
-R3(10 ohms) colour code: brown black black.
-T1 almost any low voltage NPN transistor will do.
-L1 LED i used a red one.
-potenciometer(optional)
-jump wires
-breadboard
-2 1.5 volt bateries and pack for them
for the second one you will need:
-R1 (LDR) 10K
-R4 (10K) colour code: brown, black, orange.
-R3(100 0hms) colour code: brown, black, black.
-T1 any low voltage NPN transistor
-jump wires
-breadboard
it cost me under 1€ to make this, everything was salvadged from old radios, etc...
exept the LDR, but you can easiy get one from those light switch thingies at the dollar shop, or from the internet very cheap... add some more stuff if you get it from the net though... you dont wanna pay 10 cents for the part and 8 dollars for shipping =|
Remove these ads by
Signing UpStep 1Turn LED off when theres no light
dont forget the round part of the transistor is facing you!
DONT FORGET THE POLARITIES OF THE LED!!!
http://s498.photobucket.com/albums/rr346/AmandoAbreu/?action=view¤t=100_2562.jpg
http://s498.photobucket.com/albums/rr346/AmandoAbreu/?action=view¤t=100_2574.jpg
i only have one motor yet though xD
but yea if its a small motor, its fine, if you want to use bigger rmotor, you'll have to put another transistor
cool project
In the first circuit...
Turn LED off when there's no light!
If i use 5VDC for the power supply do i need to change the resistor on the base of the transistor if so, at what value. Also the led resistor needs to change to compensate for the leds current. BUT i have that covered.
Does any other components need to change at 5VDC. This will be tested in a circuit to detect, very bright light.
Reply would be appreciated.
try using a potenciometer, to find the resistance you need for the light you want to detect.
as stated, Got this covered.. Thanks for pointing that out.
So you're saying to use a potentiometer at the base of the transistor for base current to find the resistance i need for the light i need to detect.
How will that deterrmine the resistance of the light I'm detecting.
And what vulue would the pot need to be 1k, 5k. 20k. or Higher.
So the LDR dose not need to be replaced. i just need too lower the base current.
Reply Thanks.
