Long Reach Watering Device
10,998
50
Posted
Introduction: Long Reach Watering Device
If you have a need to water a plant that is higher than you can reach, you don't have to go and get the step ladder with this little device
Step 1: Supplies
One spray bottle (Dollar Tree: $1 - or recycle something)
some aquarium tubing
long branch or bamboo stick
either:
3 small sections of heat shrink tubing one each of 3/4", 1/2", 1/4"
heat gun
or
female to male hose adapter from the hardware store: 5/16" female to 1/4" male - $2-$4
Step 2: Remove the Cap
Unscrew the nozzle cap from the bottle
Step 3: Attach 3/4" Heat Shrink Tubing
Slide the nozzle cap into a one inch section of 3/4" heat shrink tubing and then use your heat gun to shrink it down around the cap.
Step 4: Attach the 1/2" Heat Shrink Tubing
Now, slide an inch section of the 1/2" heat shrink tubing over the previous section of tubing.
Use the heat shrink gun to shrink it down around the aquarium tubing as shown in the video.
Step 5: Attach the 1/4" Heat Shrink
Slide a small slice of 1/4" heat shrink tubing onto the tube and gently slide it up over the previously shrunk tubing section.  It will be a tight squeeze, but just be gentle and twist it a little and it should slide on.
Use the heat gun to shrink this piece down around the aquarium tubing.
Step 6: Attach a Long Stick
Tie the end of the aquarium tubing to the end of a long branch or stick. Use a rubber band or cable tie - whatever you think.  The rubber band I used is not aesthetically pleasing, but it works.  Heat shrink might be a better choice here.
Step 7: Test It Out
When you squeeze the trigger, the water should flow through the tube without leaking.
Step 8: Now You Can Reach Very High Plants
Step 9: Another Option
I also found these little adapters at the hardware store which perfectly fit my Dollar Tree sprayer bottle - aquarium tube combo.
The adapter shown is a 5/16" female to 1/4" male coupler.  About $2.75
    • Science of Cooking
      Science of Cooking
    • Pocket-Sized Contest
    • Spotless Contest
      Spotless Contest
    Very nice, that should work out very well. I like the second idea better, less work.
    The best submission, I believe thus far.
    Good luck I will be making one of these with a larger spray bottle.. I do not plant high because of watering problems... This is the answer, very functional
