Ya so i noticed very few ls mods on this site, so i decided to open mine up, and with a little help from the folks at nerf haven, see what i could do. heres what i got:
AR removal
new breach
new barrel
lsfg intigration
materials:
1/2 inch (type L i think) copper tubing
5/8 inch brass tubing (should fit over copper tubing tightly)
hot glue
wire
epoxy
super glue
tools:
power drill
knife
file
hacksaw
cost:
around 12 dollars, depending on where u get materials
warning: with this mod you will only be able to load stefans, which is not a problem and do not let it deter you from doing this mod. however, if you are dead set on using stock darts, you may simply ignore the breech and barrel mods. there will also be a brief stefan making tutorial at the end of this ible.
also note: stefans are more powerfull than stock darts anyway.
Remove these ads by
Signing UpStep 1Open up the beast
take apart your longshot. pretty self explanatory.unscrew all the screws. it helps if you either leave the screws in there holes or stick them in a cardboard template. it should look like this when you open it up.
i had a fealing it was also that guy is 1 of the best modders ive seen
why could you do such a grate paint job on your longshot but not paint your titan???????????????????????????
... it is a good paint job
2. I did not have a option to get a bbb or angel breech it because Most of the internals were missing
