3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
low-tech articulated desk lamp
If you have three small-ish chunks of wood, some rubber bands, paper, and a light bulb, then you can make your own articulated desk lamp!
Articulated desk lamps are somewhat complex mechanical objects that require an industrial context to produce, given the usual components of factory made metal parts, springs, screws, and cast plastic elements. I wanted to design a version of a desk lamp that could be produced in completely non-industrial contexts, with only naturally available materials and resources--excluding the light bulb and wiring itself, sadly.
Step 1Making the parts
making the parts
 You'll need:
a small amount of wood: a 2 x 4 will be more than enough. I used less than half a square foot of 3/4 inch thick plywood. Cut and notch it as pictured, and you've got your basics done!
a couple rubber bands. The nice part about all this is that you can adjust the tension of your lamp by just adding another rubber band. You can also easily replace them--unlike the springs and pieces in your usual desk lamp
a light bulb and electrical socket
a sheet of printer paper
Cut the wood pieces--on a bandsaw if you're lazy, and by hand if you're really hardcore about it. Wood piece 4 is a small piece that slots into wood piece 3 after everything's done to constrain the range of motion of the lamp
6 comments
Jul 19, 2011. 12:38 PMsamotl says:
I like the Renaissance-esque look of the design. On the other hand, this seems like an ideal project for a 3D printer.
Dec 5, 2010. 12:29 AMjgmaciasf says:
i love it! i just dont understand the little wood piece...
Oct 29, 2009. 1:35 AMmycroftxxx says:
 The design is very nice.  How accurate do the cuts need to be?  Unless I am missing something basic, some of these cuts seem difficult for an unskilled person to make.
Oct 26, 2009. 5:51 PMrimar2000 says:
Nice design!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jihster
