magnetic silly putty by mikeasaurus
Featured
Thinking Putty (also known as Silly Putty) is a silicone polymer children's toy. Silly putty is fun because it has some unique properties: it is viscoelastic, meaning it can be stretched and shaped and mashed back together again; and as its apparent viscosity increases directly with respect to the amount of force applied (read: it can be torn or shattered with impact). Silly putty is a non-Newtonian viscoelastic polymer, better characterized as a dilatant fluid. Also, it bounces.
Ok, enough science. I'm sure we've all played with Thinking Putty in our youth, but how about magnetic silly putty?
By adding a ferrous component to an already wacky toy we can keep all characteristics of the original putty, but now have the additional dimension of magnetism! I've seen magnetic thinking putty for sale on other websites, but I'll show you how you can make your own for a fraction of the price and in about 20 minutes.
Enough talk, let's make some magnetic putty!
Step 1: Tools + materials
    tools:
  • disposable gloves (latex or other)
  • disposable face mask
  • disposable work area (paper plate)
    materials:
  • Thinking Putty ($2.00 or less) - any colour
  • ferric iron oxide powder (artist supply stores)
  • neodymium magnet
The secret ingredient that makes the putty magnetic is an iron oxide powder, which is ferric (magnetic). Ferric iron oxide is a fine powder used as black pigment and can be found at art stores. If your local artist supply store doesn't carry it, you can always purchase it online.
Step 2: Prepare putty
Start by clearing a space to work, make sure it is well ventilated. Iron oxide powder is very fine and inhaling it is probably not such a good idea. Put on your gloves and face mask before you begin.
Open the thinking putty and remove from the container. Work the putty in your hands a little to warm it up, then stretch it out like a sheet and lay it on your disposable work surface (sheet of paper or paper plate).
Step 3: Add iron oxide
Thinking Putty comes in different sizes, depending on where you purchase it. I found mine in a local toy shop, it comes in an egg-shaped container and is about 24 grams (0.8 oz).
For this size, I used about a tablespoon of iron oxide, you may require more or less depending on your putty size and amount of magnitism desired.
Carefully spoon the iron oxide into centre of putty sheet, then close lid on iron oxide powder to reduce excess iron dust escaping.
Step 4: Work it
Gently fold edges of putty sheet into centre and work the powder into the putty. Go slow, the powder produces lots of dust.
After a minute of massaging the putty it will lose it's colour and begin to look black as pitch. Keep massaging putty for about 3-4 minutes.
Step 5: Experiment and have fun!
That's it, you're done! Grab your magnet and start experimenting with your new magnetic putty.
You can stretch out a strand and make it follow your magnet, you can polarize your putty to work as a magnet itself, and then there's the classic of placing the magnet directly on the putty and watching it envelop the magnet. There's plenty of fun to be had, check out the video I made with some of the fun you can do.
Some frames have been sped-up to illustrate magnetic properties.
Of course, aside from being magnetic your putty still retains all the properties of the original Silly Putty.
Caution:
Putty has been known to leave a residue on some surfaces, even more so with the iron oxide powder. Use caution when playing with your magnetic putty.
If you get magnetic putty stuck to fabric you can try placing the magnet on top of the fabric and the putty may work it's way out (wait 24 hours). Alternatively you can apply rubbing alcohol to area and work out the putty, try a concealed test-area first. WD-40 may also work. If all else fails, take the fabric to the dry cleaners and tell them it's a silicone-based stain.
What are you waiting for? Get going and make your own magnetic putty!
Place a picture or video of your version of magnetic putty in the comments below and earn yourself a digital patch and a 3-month Pro Membership to Instructables.com!
Have fun!
1-40 of 248Next »
mikeasaurus (author) says: Jun 10, 2011. 9:55 PM
No.
Oxide powder is found in lots of pigments and is a descriptive term used for the mashed up minerals used to create what particular pigmentation, not all oxides are magnetic. Iron oxide is ferrous (magnetic) and is found in black or red.
But iron isn't the only magnetic mineral that is used in pigments. There might be another colour that works! Why not bring a magnet to the store and see which ones are magnetic? (hint, hint!)
I'll even double the 3-Month membership and throw down mad patches to anyone to post a colour other than black!!
ian9114 says: May 9, 2013. 6:11 AM
is this the stuff i don't want a whole lot, http://www.amazon.com/gp/product/B005VEDM0K/ref=ox_sc_act_title_1?ie=UTF8&psc=1&smid=A2BHZF73QCEZYR
love the Instructable
mikeasaurus (author) says: May 9, 2013. 8:15 AM
Black Iron Oxide pigment, looks like the same stuff I used. Good luck!
ian9114 says: May 9, 2013. 10:31 AM
I have glow in the dark silly putty do you think it will still glow after i mix in the Black Iron Oxide
mikeasaurus (author) says: May 9, 2013. 12:31 PM
I doubt it glow in the dark putty will retain that characteristic after mixing, black iron oxide is a pigment.
glagar5678 says: Jan 13, 2013. 2:37 PM
o. my. goooooooooosssshhhhhhh! thats amazing!!!
moskay says: Jan 8, 2013. 2:38 AM
Awesome
yinyumi says: Dec 21, 2012. 1:09 PM
Where can I buy the Thinking Putty & neodymium magnet??? I really would like 2 know i'm making christmas gift 4 my family @ last minute.
jmcconnell5 says: Dec 17, 2012. 5:03 AM
I made some of my own, here it is with a magnet inside that was absorbed by it :D
I tried adding a green chalk like substance to make it green again and it ended up being a dark olive drab, so it didn't work too well...
gumcrazy says: Dec 12, 2012. 1:37 PM
This looks fantastic! I'll swing by the art shop to see if they have what I need
jhuang7 says: Dec 2, 2011. 11:06 PM
can i use Precious metal because i dont have any iron oxide powder
mettaurlover says: Dec 11, 2012. 6:16 PM
No, it has to be ferromagnetic in order to work, and I'm reasonably certain that no precious metals can stick to magnets.
mitch and sean says: Jun 30, 2011. 4:19 PM
Is it the smart mass thinking putty or can it be bouncing putty . Does it have to be that exact putty.
yapoyo says: Dec 7, 2012. 4:58 PM
it relies on the iron so u can use any putty
yapoyo says: Sep 15, 2012. 1:21 PM
Any putty my friend.
dzmelik says: May 23, 2012. 4:48 AM
Yea I'm not sure which putty we need
kooldoode says: Jun 20, 2011. 8:15 PM
But if silly putty is a silicone based substance wouldnt hitting it with high voltage heat it up and possibly turn it into a glass like substance?
haha my little bro made silly putty in his class, may borrow it for experimentaion......
Yokel says: Dec 4, 2012. 7:41 AM
Nope, it might if the silicone was actually silicon ...
ncaguioa says: Nov 29, 2012. 7:24 AM
i used magnet sand well i came up with the name..
1.get a magnet
2.bury it in sand
3.take it out
4.and waaaala here is magnetic sand!!!
almateus says: Oct 23, 2012. 7:00 PM
I didn´t read the 432 comments, so I have to ask you if someone else talked about it. You can make your own black iron oxide using very simple things: steel wool, vinegar, hydrogen peroxide and household ammonia. I am a chemist and I can write an instructable for this (if nobody did it already). Unfortunately it is hard to find silicone putty here in Brazil... I will have to try this with white glue slime instead.
mr.mountaineer says: Sep 15, 2012. 11:51 AM
Would fine steel shavings like this from grinding work?
mikeasaurus (author) says: Sep 15, 2012. 1:55 PM
I caution against trying it.
Steel will work as it's ferrous but I have reservations about using anything other than a fine powder, like the one I show in this project. For reference here's my first attempt at this project using finely cut steel wool, the results worked but I got painful slivers in my fingers no matter how fine I cut. You may find that though your 'shavings' or 'grindings' get stuck in your fingers.
mr.mountaineer says: Sep 15, 2012. 2:28 PM
Thanks for the reply. but i still might have to give it a try. some of the shavings are as fine as powder so maybe I'll try to find something to sift it with. they say nothing ventured nothing gained and whats a few metal shavings in your fingers for science. and if it don't work I'll have to find some of that stuff in a jar. Thanks for the advice.
Rebreg says: Oct 1, 2012. 3:31 PM
Yeh really fine steel should work. My dad have a metal shop and I have been collecting lots of shavings
darman12 says: Sep 15, 2012. 8:02 AM
One question, when you play with the putty, will it ferric dust get left behind, or will the putty hold on to it?
slash51 says: Sep 15, 2012. 3:19 AM
Old hard drives have a powerful magnet in them. New ones do too but ...
darman12 says: Sep 15, 2012. 7:57 AM
I have this Instructable outlining how to take apart a hard drive, if anybody wants to go about getting the neodymium magnets: GEEK-TO-YOU: How to take apart a hard-drive (humor included)!
darman12 says: Sep 15, 2012. 7:55 AM
Nice Instructable! It's gonna be so much fun! Also, you have 101 Instructables...binary for 5...I just geeked out :)
AussieAnglerGal says: Sep 15, 2012. 3:58 AM
totally cool!
jpineda6 says: Sep 12, 2012. 7:01 PM
Hey man can i replace the neodymium magnet for any magnet.
mikeasaurus (author) says: Sep 12, 2012. 11:42 PM
Don't any magnet has the magnetic attraction that neodymium magnets do and might not be able to overcome the viscosity of the putty. Luckily neodymium magnets are inexpensive, I just saw some at the Dollar Store recently!
Kiteman says: Aug 8, 2012. 9:32 AM
Don't feed this to any hamsters!
Terranan says: May 29, 2012. 12:19 PM
OMNOMNOMNOM MAGNET
jhuang7 says: Nov 30, 2011. 10:22 PM
Does it shatter?
or_ford98 says: Jan 20, 2012. 11:07 PM
the real question is... but will it blend?
fantastikrauss says: May 7, 2012. 8:25 AM
This guy gets it.
BLUEBLOBS2 says: Mar 24, 2012. 6:44 PM
(removed by author or community request)
lemonie says: Mar 25, 2012. 2:24 AM
What are you just saying?
L
techno guy says: Jun 16, 2011. 3:18 PM
How do you polarize the putty?
mikeasaurus (author) says: Jun 17, 2011. 8:44 AM
You can polarize the putty (albeit temporarily) by having the magnet rest against the putty for a few moments (without the putty devouring the magnet). When the magnet is removed the putty should keep it's polarity and be able to lift small, light objects like tacks and paperclips.
1-40 of 248Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
