magnetic silly putty
Step 5Experiment and have fun!
experiment and have fun!
That's it, you're done! Grab your magnet and start experimenting with your new magnetic putty.
You can stretch out a strand and make it follow your magnet, you can polarize your putty to work as a magnet itself, and then there's the classic of placing the magnet directly on the putty and watching it envelop the magnet. There's plenty of fun to be had, check out the video I made with some of the fun you can do.
Some frames have been sped-up to illustrate magnetic properties.
Of course, aside from being magnetic your putty still retains all the properties of the original Silly Putty.
Caution:
Putty has been known to leave a residue on some surfaces, even more so with the iron oxide powder. Use caution when playing with your magnetic putty.
If you get magnetic putty stuck to fabric you can try placing the magnet on top of the fabric and the putty may work it's way out (wait 24 hours). Alternatively you can apply rubbing alcohol to area and work out the putty, try a concealed test-area first. WD-40 may also work. If all else fails, take the fabric to the dry cleaners and tell them it's a silicone-based stain.
What are you waiting for? Get going and make your own magnetic putty!
Place a picture or video of your version of magnetic putty in the comments below and earn yourself a digital patch and a 3-month Pro Membership to Instructables.com!
Have fun!
31 comments
Jan 25, 2012. 9:28 PMericmcd84 says:
I wasted $17 today to learn that not any black pigment will work. I even brought the magnet into the art store and tested the pigment which was definitely magnetic, but when mixed with the putty it wasn't anywhere near strong enough to even phase the magnets. The magnets I used are insane too - they have an attraction field of about 3-4". And I can't find Schmincke pigments anywhere locally. I guess I get to go back and find some pigments with serious magnetic attraction. The other huge difference I noticed in mine versus the one shown was that mine was very dry and very hard - the putty shown looks almost like a liquid. I have no clue what I'm doing wrong, but I'm going to blame it on the pigment I bought and try again.
I did learn that ferric pigments are only in the earth-tone range, though - black, brown, yellow, red, and orange. So no blue, green or violet.
Nov 30, 2011. 10:22 PMjhuang7 says:
Does it shatter?
Jan 20, 2012. 11:07 PMor_ford98 says:
the real question is... but will it blend?
Sep 20, 2011. 10:13 AMttrevor2 says:
Funny I thought I read that I should wear gloves, but in the photos the guy doesn't have gloves and in fact has very dirty fingers.
Jun 30, 2011. 9:49 AMMutantflame says:
Are you still offering the 3 month membership? I made it with red iron oxide and it works!
Sep 21, 2011. 8:00 PMThoth says:
Not sure if the offer stands but either way Jacquard's Pearl Ex Pigment's Antique Silver (#662) and Sunset Gold (#665) exhibit magnetic propeties (the neodynium magnet stuck to the side bottle of pigment as an in store check). Possibly The other metallic pigments in the line are as well but that was what was in stock at the time.
Here is a pic of silly putty mixed with the Antique Silver pigment (sunset gold look similar because of the silly putty color) The metallic sheen doesn't show so well in the pic.
Jul 1, 2011. 4:34 AMmitch and sean says:
I'll try and get a picture of me making it and the amount of the stuff.
Jun 30, 2011. 4:22 PMmitch and sean says:
I don't understand what you are giving out to someone? Pls reply because I want to post something and pls answer my other questions.
Jun 30, 2011. 10:51 AMMutantflame says:
thank you!
Jun 8, 2011. 4:44 PMGuytron says:
Any rule of thumb for how much powder the putty will take up? I'm thinking of adding some graphite to try including conductivity in the putty's behavior.
Jun 10, 2011. 8:12 AMreoozeit says:
Any idea for how you will figure out the ampacity (a.k.a. the amount of electrical current it can handle)? the thought of projectile putty if you exceeded it could be scary! ;) Also, current flow is the free electrons moving through a conductive material. What would happen if the material also moves unlike a somewhat rigid copper or aluminum that retains it's shape? electricity moves at the speed of light. I sure hope your putty does not (could be cool, but dangerous):) I think you need to try this and do an instructable that shows the results! As always,be careful.
Sep 20, 2011. 10:16 AMttrevor2 says:
Einstein would be very angry if putty moved at the speed of light, because that would violate his theory of relativity.
Jun 30, 2011. 4:24 AMreoozeit says:
My comment above was mostly a joke. Just want people to take electricity seriously. Experimentation should be encouraged as that is how we all learn new things and new things get invented. Just please be careful when dealing with things like electricity, explosives, sharp objects, politics, etc. People could get hurt!
Jun 29, 2011. 4:23 AMlegless says:
Electricity does not move. Also one needs to define electriity. Are you talking about electric current or electromagnetic energy? I am not going into the concept of an "Electron Sea" or "Charge Sea". Electric current flows extremely slowly; exact speed is dependant on the value of the current. A charge actually moves quite slowly through a copper conductor but the electric field may move at speeds approaching the speed of light. No information is carried by the charge but is moved by the electric field.
Jun 29, 2011. 10:03 PMmitch and sean says:
this is so cool can you pls tell me exact amounts of stuff and where i can get everything when im in australia?
Jun 17, 2011. 8:14 PMGuytron says:
conductive elastic polymers based on graphite are not capable of handling high current loads although they do respond in an interesting fashion to high voltage. Some types of artificial muscle are based on the response of conductive elastomers to high voltage fields. I'm more interested in the ability to conduct signal than I am in supplying power.
Jun 9, 2011. 2:17 PMmultifacetedval says:
Do let us know what happens. Will you use pencil dust?
This is really shaping up into ideas for science fair projects! I need to link to this page from my blog!
Jun 13, 2011. 12:33 PMtgrable says:
Here's the backlink. Notice how I invited students to read the comments for science fair ideas.
http://soapboxbyval.blogspot.com/2011/06/what-if-you-could-control-flow-of-slime.html
Aug 25, 2011. 3:49 PMELITE-01 says:
Dude, this is the shiz-nit
,No joke you should patent that for some major bucks
Jul 11, 2011. 10:48 AMmk2001 says:
i want to make it sooo badly !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Jun 29, 2011. 10:01 PMmitch and sean says:
that is so cool
Jun 27, 2011. 9:08 PMsbarker2 says:
and my mum always has silly putty >:3
Jun 20, 2011. 8:15 PMkooldoode says:
But if silly putty is a silicone based substance wouldnt hitting it with high voltage heat it up and possibly turn it into a glass like substance?
haha my little bro made silly putty in his class, may borrow it for experimentaion......
Jun 16, 2011. 3:18 PMtechno guy says:
How do you polarize the putty?
Jun 17, 2011. 6:00 AMmmartin7 says:
the magnet is the only polarized thing in this experiment
Jun 17, 2011. 5:59 AMmmartin7 says:
you dont
Jun 15, 2011. 6:36 AMjbillan says:
The track is by Bonobo - Transmission 94 (parts 1+2)
Love their stuff. I also love this putty!
Jun 13, 2011. 5:50 AMminomom says:
What's your soundtrack?
Love the stretch.
Jun 11, 2011. 2:09 PMTheWaddleWaaddle says:
The video reminded me of Spiderman 3 :D
-TheWaddleWaaddle
Jun 11, 2011. 8:35 AMthalass says:
Very interesting. Has anyone tried this magnetic silly putty in a coilgun?
Jun 8, 2011. 8:01 PMjnaude1 says:
I have a recipe for making silly putty so I'm going to experiment with doing it for scratch. Plus this gives me great ideas for making all my non-newtonian recipies magnetic! (magnetic gak, moon sand, etc... :D)
Jun 9, 2011. 7:03 PMArc413 says:
What is the recipe? I've just had a quick hunt, and couldn't find any.
Care to share? :)
Jun 10, 2011. 4:04 AMhwatson2 says:
http://www.filthwizardry.com/2008/06/silly-putty.html
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
627
Author:mikeasaurus(michaelsaurus.com)
Editor and Community Manager at Instructables, here to help you make fun and inspiring projects! I like mixing old ideas with new and reusing things not for their intended purpose; the results are s...
more »
