Magnetic Wire Motor Masco G32
Introduction: Magnetic Wire Motor Masco G32
Magnetic wire Motor
Step 1: Materials
D battery (1)
Magnet (1)
Magnet wire
Rubber bands (1-2)
Paper clips (2)
Sand paper
Step 2: Bend Paper Clips
Take one side of the paper
clip and bend it up and then
create a dip. This will resemble an
“S” shape with the tip bent up.
Do this to both of them.
Step 3: Magnet Wire
Cut a piece of magnet
wire- roughly the length
of one’s arm span.
Step 4: Manipulating Wire
Twist the wire into a circle, overlapping
several times. When tying the “legs” make it
directly in the center and have them putting
straight outward. Then cut them to the same lengths.
**very important the circle is symmetrical and the legs are in the center
Step 5: Shaving Wire
With the sandpaper,
shave one leg completely
(Going all the way to
the base) and the second
leg only halfway (edge to base).
*read why on next slide
Step 6: Why You Shave the Wire
Shaving the enamel off of the wire allows
for the magnetic current. One side is always
connected to the battery and one side
switches off momentarily (opposite poles)
but continues to move forward from built
up momentum.
Step 7: Assembling
Hold both paperclips
to the sides of the D battery,
facing the same way.
Attach them with a rubber band-
an additional rubber band can be
used if need be.
Step 8: Magnet
Place the magnet
on the top of the
battery- in between
the two paperclips.
Step 9: Attaching Wire
Gently place both
legs on the dips
in the paper clips
so they act as a holder.
Now the wire loop
should be rotating in circles.
Step 10: Troubleshooting
  • Circle isn't symmetrical
  • legs are not in the center (or flat)
  • wire isn't completely shaved
  • paperclips are too high up
(wire loop should be close to magnet)
Step 11: Improvements
Attach two batteries together
side by side and increase the
number of magnets for increased speed.
    • Epilog Challenge 9
      Epilog Challenge 9
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
