3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
make a PAC LITE only smaller
Build this handy little torch that can be kept in spaces smaller than a matchbox and be left feeling all dandy. BEWARE this is not a project for the unpatient. it may look like a small project but in fact it will take longer to build than you think.
Step 1Materials
You Need:
1) a small LED
2) 330 ohm resistor
3) battery clip (hard shell type)
4) hot glue
5) 9V battery
6) Black permanent marker
Equipment:
-Soldering equipment
-Drill and Drill piece (size of LED)
-Hot glue gun
-Flat head screwdriver
-Blu tack
40 comments
Sep 28, 2010. 12:42 AMherbert1982 says:
great idea men, thnx
May 1, 2009. 3:28 PMLiporXT says:
indeed a great beautiful project, compliments, has estimated it the maximum, I adores the minimalistic inventions, has realized instructable a much similar one to yours, that mine it is a portable usb charger a not torch, but the small torch is however much pretty one, very good!
Sep 28, 2008. 5:04 AMKryptonite says:
Hey gud instructable, I made a version of this mixed with YAN9VUSB instructable so it's housed inthe outside of a 9v battery! heres some pics
Nov 28, 2007. 11:57 AMmarc92 says:
Nice Instructable. I especially like your drawing in step seven, very detailed. I wish more people could learn to draw like you rather than a puddle of color made in paint that "illustrates" how to build a car. :)
Nov 3, 2007. 4:54 PMGorillazMiko says:
Wait.... why do we need Blu Tack?
Jul 10, 2007. 5:18 PMYerboogieman says:
can i use a 1/4 330 ohm resistor?
Jul 10, 2007. 5:19 PMYerboogieman says:
im going huge with this more LED's!!!
Jul 2, 2007. 2:57 PMWolvesOfWar says:
hoe much Ohm is that resistor?
330
Nov 29, 2006. 11:28 AMcrapflinger says:
for the cellphone battery emergency light..you could build some form of "clip harness" type deal that the cellphone battery could fit into with the led/resistor combo could be built into...so you could keep it in your bag...and in an emergency you just pop the battery out of your phone and stick it in the clip deal...thus making it work for the light...but you'd also still be able to stick the battery back into your phone for charging it..
May 17, 2006. 4:06 PMAirforce349 says:
This step is a little harder than it seems. I've ruined two of the battery clips lower halves by trying to pry off the bottom. It seems like it is really attached on there well. Anyone have any tips on prying off the lower half.
Oct 23, 2006. 4:26 PMKboy says:
Try using the tops (with the clips) from old 9 volt batteries. they are relativly easy to remove.
Jun 12, 2006. 11:13 PMAdrenalineSpeed says:
This may even be combined with this Instructable - http://www.instructables.com/ex/i/E16CE8EC32081029BC6B001143E7E506/
I may try it tomorrow.
Apr 24, 2006. 12:52 AMfamousdave says:
Nicely done! I want to make one of these. What did you mean by "strengthen the negative lead of the LED"? How do you do that?
Apr 21, 2006. 11:06 PMJasontheperson says:
Any idea how different LEDs effect how long the battery lasts?
Apr 21, 2006. 11:08 PMJasontheperson says:
I also remember seeing a commercial version of this with two different light settings. I bet it would be difficult but not impossible to do on your own. This is a rly great money saving project. I will attempt it eventually.
Apr 21, 2006. 9:25 PMwisepig says:
awesome! thanks for the diagram -- I just went out and made one!
Apr 21, 2006. 11:27 AMpekar says:
This and the Tic-Tac light have given me some ideas. To get smaller/simpler, consider using a 3.7v Lithium ion cell from a small digital camera. My Pentax Optio uses a battery (D-L 18, and NP-40) that I was able to buy for $8.00. That is readily available via Ebay or Amazon third tier sellers for cheap. These wouldn't require a resistor either, but would require some ingenuity to attach the bulb/switch to the pack. I'd recommend using whatever you have a charger for. There should be many cellphone battery possibilities as well. Correct me if I'm wrong, but you should be able to connect more bulbs in parallel and get a brighter light.
Apr 21, 2006. 3:13 PMpinski1 says:
You could just solder wires to the battery contacts, thing is phone batteries often have 3 or more terminals, so you'll need to test it.
Apr 21, 2006. 5:22 PMpekar says:
Yes, but it might not fit back in the charger if you do so. PDA battery packs are another possible surplus score. Electronics Goldmine has a Handspring pack on sale now for $5.
Apr 21, 2006. 2:57 AMJonQ says:
What 25$ for a Pac Lite!!? Man awesome work I'd rather make my own than pay 25 bucks for one.
Apr 20, 2006. 4:58 PMwisepig says:
great project but i don't fully understand the switch. how does it work?
Apr 20, 2006. 2:42 PMmrtools says:
is it a 9v LED or any kind? is it imposoble to use a soft 9v snap or just harder
Apr 20, 2006. 1:48 PMpinski1 says:
You could look into buying some glow in the dark paint, I think Humbrol do it in small 22ml pots ? I was thinking of using 2 5mm super bright white LEDs, mmm bright ...
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
15
Author:puffin_juice
