3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
make a Steampunk pen knife
Step 9Update, optional engraving and inlay
update, optional engraving and inlay
  • last photo ←
After having read the comments I have noticed that some viewers argue that this does not look Victorian enough to be called steampunk, so in answer to this I have made an update of an optional step of how to engrave metal wire into the wood. To make the inlay start by drawing the design on transparent drafting mylar and tape it down with double edge tape. Then use a hobby knife to cut lines ,then carve a groove with a router bit. The router will leave a rough line so carve it with a chisel. For the brass lines use 1/16 wire, and bend it so that it fits in the grooves then use super glue to adhere the pieces. This will most likely leave a mess of glue, either way use a file to remove the top layer of wood, glue and metal; this cleans the surface as well as making the wire seem wider.
1 comment
Sep 17, 2011. 12:40 PMsconner1 says:
Nice inlays, it really pops against the rosewood.
It would be cool to put only period tools in.
Phillips screws although superior weren't invented yet.
A straight shaving razor would be, even if it were difficult to use and maybe even downright dangerous.
I like the idea someone posted about including a clock key.
Steampunk is fiction after all so go ahead and add bluetooth :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
14
Author:alexander.m
